I've decided to go with this cam...what do ya'll think.Particularly Rich
Old Aug 11, 2005 | 09:06 PM
96vortechSS's Avatar
TS-230XL 230/242 duration, .544"/.576", 114lsa
I'll probably have it ground on a 116lsa instead of the 114lsa.
How much more power do you think the 116lsa will have over the 114lsa?
Old Aug 11, 2005 | 09:10 PM
rskrause's Avatar
Moderator
Re: I've decided to go with this cam...what do ya'll think.Particularly Rich
It will likely make a few less hp but have better manners with the 116lsa vs. the 114.
Rich
Old Aug 11, 2005 | 09:35 PM
What rpm do you think the cam will peak at with 190cc LT1 fully ported heads?
I really don't want to take the motor past 6500 rpm. Would this cam be a better choice: TS-227XR 227/239 duration, .560"/.577", 114lsa
Will either of these two cams make more than the low lift 224/236 114lsa cam?
Old Aug 12, 2005 | 11:12 AM
rskrause's Avatar
Moderator
The two cams are quite close but I prefer the shorter duratio/higher lift combination if you are willing to run enough spring to handle the more aggressive lobes. I would expect a peak lower than 6,500, so no worries there.
Rich
Old Aug 12, 2005 | 01:05 PM
RealQuick's Avatar
Ground on a 116lsa, i suspect 6000-6200rpm peak...
Old Aug 12, 2005 | 04:04 PM
Thank you for the answers.
Will these two cams make more power than the low lift 224/235 114lsa cam?
Old Aug 17, 2005 | 03:50 PM
Rich, the 227/239 cam mentioned above. How would the power compare to the high lift version of the 224/236 cam?
Old Aug 17, 2005 | 10:16 PM
rskrause's Avatar
Moderator
Again, these are all going to be pretty similar. The high lift XE lobes need a lot of spring and such, most peple are going to be better off with the lower lift lobes. Are you willing to invest in a good set of springs, pushrods, and titanium retainers?
Rich
Old Aug 19, 2005 | 01:42 PM
ZBLKHELLRZR's Avatar
Rich
Will CC918's handle either one of those cams?
Old Aug 19, 2005 | 02:38 PM
JustNO's Avatar
absolutely
Old Aug 19, 2005 | 02:39 PM
JustNO's Avatar
I think 116 lsa is too wide.. 114 or 115 would be my choice..
Old Aug 19, 2005 | 03:18 PM
Thanks Justno. Well that's one thing taken care of. Now to figure out the rest.
Old Aug 25, 2005 | 04:31 PM
mzgp5x's Avatar
My 4th cam. Cammotion... 231/240 I/E with .538/ .558 I/E on 110 deg and 114 LSA. From Cam motion. I like the high rpm cam. 3K to 6.5k range. I'm running with afr 190's and the hydra rev kit. The hydra rev helps control valve float @ 6K+ rpm. Not that bad @ idle 1100rpm. I did notice better breating as my manifold boost pressure dropped. Thinking of spinning the ati faster (3.4 pulley) due to lower pressure.
magman
Apr 15, 2016 03:08 AM
David Dempsey
Mar 12, 2016 12:42 AM
Bxlt1
Sep 29, 2015 03:18 PM
drt
Sep 27, 2015 04:39 PM
