its official, I'm joining the ranks of the boosted
Old Aug 10, 2007 | 01:43 PM
  #16
92LT1RS's Avatar
now, if only I had an engine to bolt it to
Old Aug 10, 2007 | 05:21 PM
  #17
1fastgixxer's Avatar
Originally Posted by 92LT1RS
are the 60# injectors big enough? I was under the impression I would be well past what they could support. If I can get away with that I'd definitely do the meth setup instead, especially with the high temps down here during the summer.
according to my turbo calculator the 60lb-ers can hadnle up to 1000 hp at 11.5 afr
Old Aug 10, 2007 | 05:43 PM
  #18
streetbad's Avatar
At what fuel pressure? Thanks -Tim
Old Aug 10, 2007 | 05:53 PM
  #19
streetbad's Avatar
talked to Lonnie this evening and he's working up a price for me for a universal Procharger F-1 kit. pullies for 10 and 15#,
What Diameter for 10Lbs?..... ,15Lbs? Crank is 7.65?? Thank you Your blower is gorgeous!!
Old Aug 10, 2007 | 06:41 PM
  #20
95 Z/28 LT1's Avatar
Super Moderator
You'll be glad you went with VRE. I have had nothing but great experiences with them and their engines are top notch!
Old Aug 10, 2007 | 09:50 PM
  #21
44psi
Old Aug 10, 2007 | 11:25 PM
  #22
Jeff 96 SS's Avatar
Throw away that calculator or the motor you try that on your choice!
Attached is a calculator that is not bad but none of the calculators are fool proof! http://www.rceng.com/technical.aspx
Old Aug 11, 2007 | 05:49 AM
  #23
no it was operator error. thought i had it set on 44psi but it got to 90psi some how . so you could pull it off with a fmu.
Old Aug 22, 2007 | 10:07 PM
  #24
92LT1RS's Avatar
so FedEx can blow me. it appears they've misplaced the entire topend of my engine, heads, intake, cam, all valvetrain parts. bastards. was supposed to be here on Monday at the same time as my big-block hub balancer. Balancer showed up, rest of it didn't they've "started a trace" to find everything but I won't find out till at least tomorrow too bad I'm leaving first thing Saturday morning to go back to school. *******s.
Old Aug 22, 2007 | 10:09 PM
  #25
92LT1RS's Avatar
I ended up with a 7.65 lower pulley and a 4.0 upper. going to find out around Christmas time what boost I end up with using that combo and go from there.
Old Aug 23, 2007 | 06:38 AM
  #26
JakeRobb's Avatar
Super Moderator
not going anywhere near a track though until I can get a 9" or 12-bolt
Dana 60. Cheaper, lighter, and stronger than a 12-bolt.
Old Aug 24, 2007 | 05:24 PM
  #27
streetbad's Avatar
How much boost did Lonnie estimate with the 4.0?
Old Aug 26, 2007 | 08:08 PM
  #28
Chvywolf's Avatar
I'm not sure anyone else has been able to Procharge an LT1 in a 3rd gen before. none that I'm aware of anyway.
Not that I know of either but I'm about 6 months behind you, and I will be watching very closely. Thanks for paving the way so to speak. Mind if I pick your brain some when I start moving forward?
Old Aug 26, 2007 | 08:14 PM
  #29
92LT1RS's Avatar
I believe we were figuring on the 12-12# range to begin with, then upping it to around 15-16 later on after everything is running and broken-in
absolutely, I'd be more than happy to help out someone else. what are you planning on running?
and as far as FedEx goes, apparently they found "part" of the shipment of parts and expect to find the rest of them Tuesday
Old Aug 26, 2007 | 08:21 PM
  #30
Chvywolf's Avatar
Currently the car itself is being prepped, just recently finished the subframes and 8 point, but the ultimate goal is a 396 LT1 with 15lbs. I'm looking for as close to 700 at the wheels as possible. It may take some time but I want to do it right. And believe me, I've been doing a whole lot of research and "search" functions on the boards. But so far like you said, first time with an LT1 in a 3rdgen. It's pretty close to an L98 but different enough to make everything aggravating.
My current battle is with the clearance for the long tubes. Thankfully I have a welder so that should be taken car of soon.
