Injectors and Fuel Pump
I want to order 42 lb. injectors and I believe they need to be low impedance with a stock set up. I've seen deals on E-Bay for the green tops for Mustang applications. Would they fit and would they be low impedance. No info on site.
I also need a high Volume Fuel Pump, what kind to buy and where.
Thx
Armin
Thx
Armin
Re: Injectors and Fuel Pump
I have a set of 42lb injectors barely used that will work with your stock PCM, unless you buy an impedence converter or an aftermarket PCM you need high impedence (aprox 14 ohms)
Thx
Armin
Thx
Armin
