how much hp with 50#ers ?
Old Oct 28, 2003 | 03:07 PM
sideways_Into_3rd's Avatar
whats the max HP supported by 50#ers on boost ?
what if i put up the pressure to about 60 psi ?
i think i've been talked out of running and FMU . so im trying to figure out what i can get away with with 50#ers
Old Oct 28, 2003 | 03:20 PM
95 Silver TA's Avatar
I hear most guys here can run in the Mid 500 RWHP with 50s but then they start to lean out. I have heard of a FEW cases with some folks running upto 600RWHP with just 50s and no superfueler or FMU. I am sure some folks will Jump in here and give you more specifics.
I am currently running 50#ers with no problems (see sig for more details) but I have not had the car on the Dyno yet but I am only shooting for around ~450RWHP and wanted more room for HP growth later on.
Thx,
Claude
Old Oct 29, 2003 | 01:11 AM
1LEThumper's Avatar
I hit 567rwhp on my before they gave up the good fight....they are forsale right now as well if you would like them.
This was on a Mustang Dyno...no FMU, ATI car.
Old Oct 29, 2003 | 06:38 AM
IDOXLR8's Avatar
If you plan on going with 50lb injectors then I would highly recommend staying away from MSD injectors. They tend to stick at high fuel pressure.
Old Oct 29, 2003 | 07:58 AM
rskrause's Avatar
Moderator
Somewhere around 500-550rwhp. DO NOT exceed ~80% duty cycle, going lean on a boosted motor is a major no-no.
Rich Krause
Old Oct 29, 2003 | 02:40 PM
sleeperz28's Avatar
I would recommend a sieman injector. Very good quality! I guess im playing with fire, but I have been running them in the 95% duty cycle range for about a month. I would like to keep them around 80% but there is not a decent injector with the size to suit my needs.
Old Oct 29, 2003 | 04:41 PM
1LEThumper's Avatar
The MSD's in my car did just fine until they hit 90-100% duty cycle. I do agree, I wouldn't run them with a FMU though...but I don't have one on my car and they work just fine with a base pressure of around 45 (hits 60psi under full boost).
Old Oct 29, 2003 | 04:57 PM
Highlander's Avatar
Well..They were good for around 500rwhp... after that I am using an FMU, but funny thing is that I have not had any problems with them and 60-62psi of fuel pressure... I start at 55psi and with boost they rise till 62... Maybe I can lower the pressure since I ahve an FMU with 3 96# that will really help when I need it.. I expect more fuel need since I changed the plate on the superfueler and now my superfueler has a bar with 10 holes in it
I just dont get how the mustang people get 600s+ with theese injectors...
OrionSPL
Nov 25, 2003 09:16 AM
OrionSPL
Nov 25, 2003 06:31 AM
sideways_Into_3rd
Oct 29, 2003 08:35 PM
WHYTLIE
N2O Tech
Jun 2, 2003 04:08 AM
