How much fuel pressure
Old Sep 11, 2006 | 08:56 PM
michael_grayson's Avatar
Say guys how much fuel pressure do you run with your stock lt1 with a procharger, mine shows 48lbs at idle last I looked, the thing runs way rich and will spit and sputter and leave a black cloud. Its has a brand new opti. all the o2 sensers are fine. The MAF is on the boost side, and brian at pcmforless did a tune on it. Could the FMU be messed up and loading fuel with out boost. any suggestions
Old Sep 11, 2006 | 09:21 PM
cjmatt's Avatar
Re: How much fuel pressure
when the vacuum line is off the fuel pressure regulator, it should be set to 43 psi. at idle mine goes to about 38 with vacuum hooked up
Old Sep 12, 2006 | 08:27 AM
I will put my adj. regulator on and get the fuel pressure down there and see what happens, thanks for the input
Old Sep 12, 2006 | 09:25 AM
RealQuick's Avatar
Brian probably has it tuned assuming your fp is stock. Get that down and it should clear up the problem.
Old Sep 12, 2006 | 09:37 AM
97WS6Pilot's Avatar
48 is way to high for idle with an FMU. Something is amiss. Mine showed 38 at idle and it would increase as you step on the throttle based on the amount of vacuum or boost the pressure regulater sees. IE Less vacuum= More fuel pressure. The fmu doesnt do anything until it sees boost.
Old Sep 12, 2006 | 08:48 PM
thanks guys, I went to put on a adj regulator tonight that I had pick up awile back and the mounting tab is in the wrong place, its on the bottom instead of the top, I swear the guy I bought it from said it would fit a 97, so I need to find another asap
CaptainObviousI
29
Apr 29, 2021 10:35 PM
DirtyDaveW
Dec 1, 2016 05:37 PM
RUENUF
Mar 13, 2016 03:39 PM
charchri4
Apr 14, 2015 06:40 PM
Jul 4, 2005 05:00 PM
