How much boost are you running through ATI twin ICs
The reason im asking is because my car builds boost fine all the way up to about 14#s@5800 rpms and then it plains out. The belts not slipping and ive checked for kinked hoses. I have the MAF on the suction side of the blower and im starting to think that maybe thats the restriction. I have a huge filter with 4" metal tubing except for the orange dryer hose so it cant be collapsing.
I have the same problem as you described. My car made 14 psi (ATI F1) and made 705 rwhp. I think the biggest restriciton was my twin intercoolers. I am planning on going with a front mount intercooler this winter. My car flatened out at 14 psi also. The only reasons that would happen are:
1. Too small of a filter
2. Collapsing orange flex hose
3. Belt slippage
4. Intercoolers too small.
3. Belt slippage
Originally posted by 97TA-WS6-Con
I have a 15# pulley on an AFR ported 190, 383 motor.
Most I have seen is 13.4 # at about 6100.
Did you fix most of the issues with your car?
How is it running now?
Thx,
Claude
Anybody looking to buy a twin IC setup
cj, I'm interested in the twins if your selling them. How much? Email me at BaOdysseus@aol.com
Originally posted by SMOKNZ
I ran 18 psi on my twin intercoolers. But I have no Flex hose., so I don't think the intercoolers are the problem.
Thx,
Claude
BTW...If you do see this Sean, Congrats and hope everything goes GREAT!
Originally posted by 95 Silver TA
Shawn,
Thx,
Claude
Shawn,
Thx,
Claude
I went with the FAST, 75# injectors and the dual intank pump. All that went great and fuel is no longer an issue.
But for whatever reason, the rings did not seat with the last motor refreash and the car burns oil BADLY. I said screw it, I'm going to drive it for the summer and pull the motor again in Oct. As a result I have peroblems associated with burning oil such as fouled plugs.
The tuning is not TOO bad but not perfect. I have played around a lot and although WOT and moderate exceleration is fine, is it driveability that is at issue.
In summary, I have as many things to do this year as I did last year but given the need to pull the motor again, I have decided to leave most of them for now - vacuum pump, solid intake, re-plumb the surge valve into the intake side.
I only went to the track once and was only the second time I had been on drags. I also NOW know that the performance was restricted due to fouled plugs. Best numbers were a 1.99 60 foot and best time was 12.30 and best ET 123.
Only went to the dyno once, right after the drag day to find hp was 480 @ 4500 rpm and then just plummeted down. Given AFR, fuel and tune appeared to be fine I at first thought of ignition. I pulled the plugs to find they were BLACK. Burning about 1 litre of oil every 400 miles. *ugh*
Not sure why the rings did not seat. Given the car burned oil from the start and given the car was lean, not rich in the early days, I suspect builder error.
PS: Sorry to hi-jack the thread.
One step forward , two steps back.
When you orignally started up the car with new motor did you have a decent tune I have heard of a few folks washing the rings with an overly rich tune at start up.
Also did you break the motor in with Dyno Oil and was the motor primed before you started it?
Do you happen to know where they gapped your rings at?
I am not sure what could have caused your problem but these may be some of the few things you wanna check or do in October (if it was not done in your first rebuild).
Thx and Good Luck Broh.
Claude
CJ,
I have a setup similar to your old p600B setup and was wondering if there was a big increase in performance from you p600 to the D1? I'm asking because i'm considering moving up to the D1.
Are you gonna run a shot on it still?
Travis
Travis
Originally posted by TravProcharged94Z
CJ,
Travis
CJ,
Travis
