Hobbs Switches
Old Mar 2, 2006 | 11:32 PM
Fastbird93's Avatar
Hobbs Switches
After much searching, I finally found a source for these.
http://www.alliedelec.com/Search/Pro...&IND=T&SEARCH=
Now, what I need to know, are these style switches adjustable. If you go to the honeywell/hobbs PDF page, it says they are, but no guidance is given on doing this. I'd just like to know how easy it is to adjust the setting as I'm considering getting the 3.1-7 PSI switch and setting it to 6 PSI to start.
Second, for "verification" purposes, what do you all think of running a dual circuit hobbs switch and using the second circuit to light a LED mounted in the console or dash for verification that the switch is working (and a cross reference against your boost gauge to verify the switch accuracy).
Old Mar 3, 2006 | 08:08 PM
high c's Avatar
Re: Hobbs Switches
i dont know anything about that kind of switch, BUT i hade one of theses
http://cgi.ebay.com/ebaymotors/Boost...spagenameZWDVW
kind of switchs on my turbo camry and it worked GREAT!!! i used it to control my extra injectors and i was abble to keep up with c4 vettes
Old Mar 4, 2006 | 04:36 AM
2NastyZ's Avatar
Re: Hobbs Switches
Yes Hobbs switches come in 3 styles. One is set and sealed and you buy it at a set pressure. The other two are adjustable ( a screw under the cap is used to adjust it) of these two one is made to be on and turn off when the set pressure is hit. The other is off until the pressure is hit.
I use to buy these at a diesel repair shop since a lot of the big 18 wheeliers motors use them for oil shutdown and other things.
Good Luckk
Old Mar 7, 2006 | 02:26 PM
CALL911's Avatar
Exclamation Re: Hobbs Switches
I think Hobbets should not be switched. You did see what happened to Frodo didn't you? ...OH you said HOBBS
Old Mar 7, 2006 | 06:39 PM
Fastbird93's Avatar
Re: Hobbs Switches
Thanks for the help guys. Anyone know if those in the link I posted are adjustable???
Ericksd
Jan 20, 2016 06:07 PM
IndyZman
Oct 22, 2015 02:17 PM
94Z28LS1toLT1
Sep 22, 2015 05:24 PM
Rod Bender
25
Sep 16, 2015 01:47 PM
jackpawt883
Sep 10, 2015 08:53 PM
