HELP! Lt1 D1SC is is miss firing after 4600rpm
I had the car tuned last fall by Bryan from Pcmforless. The car was missing by 4700rpm. I didn't have an MSD box and he said that was most likely the problem. Well I installed one and the missing is still there. Any suggestions? It is a new opti spark when I did the engine. Thanks Lee
I hope the plug gap adjustment works. If not, what valve springs/cam are you using? I've heard of weak valve springs failing to fully close the valves when the combination of high(er) RPM and boost are in effect.
Same happened to me when I had my plugs gapped to big. One other thing to think about, would be changing the NGK's out (not good plugs at all according to PCM's for less).
I personally reccomend Autolite.
Glad to hear gapping fixed your problem.
Bingo. Exactly the plug I've used since 1996 in mine, whether Nitroused or Boosted. Gapped to .035 for me. Never missed a beat.
Nitrous best (100 shot) of 11.1 @ 121 mph full street trim except M/T ET Streets. I haven't raced at the track with the Turbo setup yet
.Thread
