Gear choice with turbo?
Old Jul 12, 2007 | 09:48 PM
  #16
maro z28's Avatar
Can someone help me understand why tall gears for turbo motors. If turbo motors generally do less rpms per speed, wouldn't you want a higher gear ratio to put you in your power band quicker? Where am I mistaken?
Old Jul 12, 2007 | 10:26 PM
  #17
engineermike's Avatar
People usually say that turbo's spool quicker under a heavy load and tall gears put a greater load on the motor. Not sure I buy into that.
One reason is that turbo motors usually peak low in the rpm range as compared to NA motors, and they typically pull alot higher mph. So, if you gear it for redline at the end of the track, you end up with a tall gear.
My car: 700 rwhp @ 5700 rpm. 146 mph in the quarter at 6200 rpm with a 26" tire and 3.00 gears. It's geared nearly perfect.
Mike
Old Jul 13, 2007 | 05:04 AM
  #18
rskrause's Avatar
Moderator
You don't have to twist a blower/turbo car to the moon to make hp.
Rich
Old Jul 13, 2007 | 08:32 AM
  #19
maro z28's Avatar
Can anyone give a link for a gear calculator? I'd like to learn how to properly gear a car. Thanks!
Old Jul 13, 2007 | 09:23 AM
  #20
RealQuick's Avatar
I have seen this to be true when riding in a manual car. Guys with autos will have trouble seeing it because of their stall speeds.
Ex. - Mashing it @ 1200 rpms in 1st gear, full spool by 3400rpm
then mash it at 1200rpms in 3rd gear - full boost by 2400rpm
LeftoverChinese
Jan 14, 2024 03:03 PM
DirtyDaveW
Dec 1, 2016 05:37 PM
Apr 3, 2015 10:54 AM
DirtyDaveW
Mar 15, 2015 07:01 PM
