fuel pump ?
Old Aug 11, 2005 | 07:48 PM
steves97z28's Avatar
fuel pump ?
is a fuel pump absoultly needed for the STS kit? im gonna be running 5psi and bigger injectors but im runnin low on money and there is a good chance im out of a garage real soon. how bad would be running it on the stock pump. i heard it'll be fine with 5lbs
Old Aug 12, 2005 | 02:00 PM
RealQuick's Avatar
Re: fuel pump ?
Should be fine. I ran stock pump N/A up to 383rwhp. My 24# injecotrs had a duty cycle of 113% though. If you can afford an fmu or bigger injectors then I suspect the stock pump will be fine for your mild setup.
Old Aug 12, 2005 | 02:04 PM
Re: fuel pump ?
ya jon the car is gonna get 42lbs injectors. problem now is we are gonna be renting the house out that the car is at, so if they find someone im kind of screwed so this project that wasnt in any kind of a rush is coming along faster then i thought. the hardest part left is fixing the intake manifold leak.
Old Aug 12, 2005 | 02:08 PM
RealQuick's Avatar
Re: fuel pump ?
Did you buy the tuning software yet?
Old Aug 12, 2005 | 02:09 PM
Re: fuel pump ?
nope not yet, i think i might just go with tunercat, its alot cheaper and i can let other people used it, potential to make some money back. how bad is the intake manifold to pull off and replace gaskets/RTV????
Old Aug 12, 2005 | 02:11 PM
RealQuick's Avatar
Re: fuel pump ?
3hr job...but the silicone has to cure for atleast 12 hours. I try for 24hrs.
Old Aug 12, 2005 | 02:25 PM
Re: fuel pump ?
ya car wont move for atleast 24hours, i dont want to do it again. also gonna try to wrap the egr tube in heat wrap, or i might just block it off.
Scottyboy
Feb 11, 2015 10:28 PM
RiverMutant96
Jan 30, 2015 09:21 AM
ANDYZ28
Dec 29, 2014 09:13 PM
Black Sunshine/ 00SS
Sep 15, 2002 10:08 PM
