Fuel problem
Old Aug 14, 2003 | 10:59 PM
GS355's Avatar
Fuel problem
I currently have this set up (383+t-trim) in my car with 42#injectors with an fmu. I upgraded my intake fuel pump to a 255 walbro. At 5500 rpms i'm seeing 10# of boost and the o2's start falling off. I changed the FMU at the fuel pressure jumped to 57psi still no big improvement. Does this sound right at 5500 rpms with 10 #s of boost. I plan to turn it up to 6500rpms. Does this sound like a job for the boost a pump, bigger injectors?????
What fuel pressure are you guys seeing? I was thinking of going with those 57# seimens injectors from racetronix. Do you guys think that might solve the problem?
Running out of solutions for this problem. Any ideas guys
GS355
Old Aug 15, 2003 | 09:12 AM
RonnieW's Avatar
Hello George, I wish I was far enough along to give you some input. I have the same fuel pump with the boost a pump. I think my opt has crapped out. I hope to get one today so I can put it in this weekend. Anyway ttt for ya.
Old Aug 15, 2003 | 11:04 AM
97TA-WS6-Con's Avatar
I had 50# injectors with a Walbro intank 255 and ran out of fuel. I have a 383 with a15# ATI D1 although I see about 13# at most. I also started with 42# injectors and moved up to 50's and finally when I got the FAST, I bought 75s
I ran out of fuel and upgraded to a dual intank pump from Racetronix. I also got some 75# injectors from Racetronix.
No problems now.
I would say you either get a boost-a-pump or get the dual intank. the 42# injectors are going to be real close, maybe need 50's.
Just my humble opinion.
Old Aug 15, 2003 | 03:42 PM
SMOKNZ's Avatar
I run 42# injectors with the Dual intank pumps. It had no problem supporting 542 RWHP, but the fuel press with both pumps on is around 70 psi. This is with a completely stock fuel system.
Bill
Old Aug 16, 2003 | 01:21 AM
Blownbird355's Avatar
dual pumps
I have been to their site many times lookin for some info on the dual pumps but never find anything, anyone have a price and are you all running the stock fuel lines?
Old Aug 16, 2003 | 07:42 AM
SMOKNZ's Avatar
Price was $500. You need to remove your sending unit from the tank and send it to the for modification. Yes I use an entire stock fuel system except the pumps.
Old Aug 17, 2003 | 11:41 AM
GS355's Avatar
Fuel injectors
Well guys, I'm stepping up to 57# Hi-Z injectors from racetronix. I hope this sovles my problem. As for the boost a pump, has any used the MSD boost pump. or is this the same peice you are talking about 97TA-WS6-Con.
George
Old Aug 17, 2003 | 09:51 PM
stock fuel lines
I guess the stock lines are better than everyone thinks.
Old Aug 17, 2003 | 10:36 PM
iniviate's Avatar
ronnie... autozone has complete lifetime warranty opti's for ~$130. i checked into it a couple weeks ago... the "warehouse" on cassat had one in stock.
Old Aug 18, 2003 | 12:45 AM
dual pumps
Damn for $500 dollars you could have new braided lines and regulator and a good single pump. Are they dual 255 walbro's?
Old Aug 18, 2003 | 01:12 AM
JordonMusser's Avatar
West South Central Moderator / Special Guest
Re: dual pumps
500 will NOT buy you a braided setup.. you will have nearly that just in fittings and crap
Old Aug 18, 2003 | 07:26 AM
Brandy's Avatar
Re: Re: dual pumps
I just spent nearly $300 redoing the fuel system under the hood on my car, and this was jobber pricing on the parts!
Old Aug 18, 2003 | 11:49 AM
IDOXLR8's Avatar
Re: dual pumps
I am currently running a custom twin intank setup made by Aggressive performance. Through stock lines the pumps have supplied enough fuel for 705 rwhp without any problems. I am also running 83 lb injectors.
Old Aug 18, 2003 | 05:55 PM
SMOKNZ's Avatar
Yup, twin Walboro 255's, all the big gauge wiring and weatherpack relays and fuses, and it plugged right in. Plus if this isn't enough a BAP will also plug right in. Its a deal and it took like 15 mins to hook up(not including the tank part)
Bill
Old Aug 19, 2003 | 10:47 AM
MEAN LT1's Avatar
Wow, I would have thought those 42's would have been enough for you with the fmu but I guess not. Good luck George, let me know if you need anything. TTT for you
DirtyDaveW
Dec 1, 2016 05:37 PM
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
Scottyboy
Feb 11, 2015 10:28 PM
97Z28Muscle
Feb 6, 2015 10:44 PM
