Crankcase evac. What did you guys do?
Old Dec 8, 2007 | 11:10 AM
  #46
c0rey's Avatar
Bringing up a old post. I was wonding if the moroso kit would work out the same if i y-d the two lines to one check valve or I will have to put on on the down pipe and another one 6 inches from it. Just wondering how the moroso set up has been so far as well. I scanned through the posts did you keep the original pvc with the moroso?
Old Dec 8, 2007 | 03:15 PM
  #47
The SRZ's Avatar
What I ended up doing was running a catch can to each VC and the PCV line I used a high end oil/water seperator.
I am not sure about your suggestion though w/ the moroso kit. I believe you need both running to their respective header.
Old Dec 8, 2007 | 04:01 PM
  #48
DirtyDaveW's Avatar
<drool> goood gawd that's beautiful! What pump are you using?
Originally Posted by Eric@Victory Racing
We decided to use a vacuum pump set up.
Old Dec 8, 2007 | 04:44 PM
  #49
Eric@Victory Racing's Avatar
We purchased it from GZ Motorsports.
Old Dec 8, 2007 | 05:17 PM
  #50
c0rey's Avatar
Well I will only have one downpipe due to the turbo. and I for sure dont wanna put it in the logs before the turbo.
Old Dec 9, 2007 | 10:43 AM
  #51
mzgp5x's Avatar
Eric, did you design an oil re_circulation system from the catch can to lubricate the gzms pump vanes??? I'm installing a gzms #103 pump on a LT1 D1 supercharger application. Had to move the radiator for space, and, the LS1 engine has much more room for the pump install. Lot of work but I got all winter. B. (97ss 383 - D1)
carguy0119
Apr 11, 2016 11:11 PM
blac94Z
29
Mar 25, 2015 04:21 PM
steve10358
Middle Atlantic
Mar 20, 2015 04:50 AM
mspennyhughes
Nov 28, 2014 03:22 PM
Red97LT1
Aug 7, 2002 05:45 PM
