cast manifold turbo guys
Old Oct 19, 2008 | 02:47 PM
glenb1991's Avatar
do you guys think it would be a bad idea to make a cast manifold hot side kit, or would the flow be too low? how bout if you got them ported a bit? im looking for a better way to route the hot side. hopefully realquick will chime in and let us kno how his manifold kit performed.
Old Oct 19, 2008 | 05:13 PM
RealQuick's Avatar
as long as you don't need more than 650rwhp, the cast manifolds should be fine. I made a kit long ago that mkent has been using... maybe he'll chime in. I made another kit with a set of ported cast manifolds, that guy hasnt run it yet to my knowledge. I have a kit I just completed ready to sell 9or install on my t/A)... with a T76 it shouldn't have any problem making 600-650rwhp. anythin more than that and you'll need to step up to a header design.
Old Oct 19, 2008 | 06:22 PM
glenb1991's Avatar
sweet. exactly what i wanted to hear. lol. now to decide if i should use corvette or camaro/trans am manifolds.... any ideas which ones are easier to change spark plugs with? im sure the camaro/trans am ones will be easier to reverse and make a crossover pipe for as they go over the top... any other opinions?
Old Oct 19, 2008 | 07:51 PM
RealQuick's Avatar
I only have experience with fbody manni's
Old Oct 20, 2008 | 08:51 AM
mkent's Avatar
I haven't had my car on the dyno yet, nor has it seen over 4psi because the fuel pumps aren't installed. It does seem like my EGT's have climbed quite a bit, and my intial thoughts are that it may have something to do with the D port manifolds mated to a rectangular port Dart head. I think on stock heads up to 600-650rwhp, the manifolds are fine.
With the turbo I'm running and with these heads, I may end up switching to a header kit later because I may be pushing more than 650rwhp...intially i didn't plan on that high of a number.
LeftoverChinese
Jan 14, 2024 03:03 PM
DirtyDaveW
Dec 1, 2016 05:37 PM
pimpss96
Feb 12, 2015 01:28 PM
spearous
Jan 12, 2015 11:03 AM
Red97LT1
Aug 7, 2002 05:45 PM
