Callies Dragonslayer and Piston Q's
Old Nov 18, 2005 | 01:10 AM
  #61
5.0THIS's Avatar
Re: Callies Dragonslayer and Piston Q's
Originally Posted by snorkelface
I think I'm leaning away from moly rings since they tend flake during detonation.
Plenty of guys run moly rings under boosted applications and have no problems. I think several of the guys in here are with their boost F bodies.. perhaps they'll chime in.
Old Nov 18, 2005 | 08:15 PM
  #62
MachinistOne's Avatar
I use moly rings in boosted apps and never have problems.
Old Nov 19, 2005 | 12:57 AM
  #63
snorkelface's Avatar
D@mnit. I never thought these little issues would be so tough to determine. It would be much easier if there was just one clear way to go.
Will regular moly rings have a problem standing up to 15-20# of boost?
Also, since I have to get custom pistons anyway and the block is in good condition, should I only over-bore the cylinders only .010 or .020 to keep a little more strength in the block, and possibly be able to bore it out some more in case of a future re-rebuild?
Old Nov 19, 2005 | 01:10 AM
  #64
5.0THIS's Avatar
I would only bore it as little as possible to get the bores pointed in the right direction and a good hone in it. You're not boring the motor for the huuuuge displacement increase and the gigantic bump in power
Old Nov 19, 2005 | 07:05 AM
  #65
rskrause's Avatar
Moderator
I get a little nervous when you start talking about 20psi. I am forgetting if it was mentioned, but I assume as a DD you are going to be running pump gas? A SBC, 20psi, pump gas, and longevity are not in the cards. If I was builiding a boosted LT1 for performance and longevity I would not plan on using more than 12psi. Get good heads, the best pistons you can, run a low CR, an intercooler and water injection.
There are some potential advantages to keeping the overbore to a minimum. You need to get it apart and inspect/measue the existing bores before you can decide this. Unfortunately, you are talking a custom ppiston for a 10 or 20 over setup. Not a huge deal, but it does add $100-200 to the cost and may limit your ring choices. May also take a few weeks, or longer to get depending on the time of year.
There is no "formula" for this unless you want to copy a sucessful setup. Even then, there are lots of BS'ers here on the web so you need to be careful who you listen to. I don't recall if you mentioned your budget or how much you are doing yourself, but another option is get a pro involved. This can be costly or cost effective depending on where you are coming from and how you are looking at it. s a rule of thumb though, once you take an LT1 past ~600rwhp you are talking about a motor with very compromised longevity even with the best of parts and assembly.
Rich
Old Nov 22, 2005 | 12:13 AM
  #66
20PSI would be VERY rare and on race gas. On the street, it would be maxed out at about 15PSI. This is all going with 8.5:1 compression, the Lunati/JE assembly etc.
I have to get a custom piston anyway because I am going with a 3.48 stroke/5.7 combo with a -31cc dish. However, if that will make the rings more difficult to source, I may just stick with a .030 over setup.
The heads are done.
I'd like to hear more opinions on whether to go with moly or Hellfire rings.
Z Power
Sep 19, 2015 11:19 PM
DelSoto
Sep 19, 2015 05:31 AM
95craz28
11
Sep 12, 2015 07:47 AM
gonzo275rltw
Sep 5, 2015 06:26 PM
gonzo275rltw
Sep 5, 2015 06:24 PM
