Burnt T4 Shim gasket...
Old Aug 24, 2013 | 10:09 AM
DirtyDaveW's Avatar
A few months ago, I got my kit ready to install and, per recommendations from others, I put a layer of red silicone sealant on the shim before I installed it. But as often happens after I got that ready, I found that I needed to disassemble a few pieces so I could insert a brace (this was a new kit and I didn't realize that the brace had to be installed after the turbo but before the crossover. Tight confines...). So, meanwhile the silicone sealant 'set' and when I put it on an hour or so later, I 'hoped' tightening all bolts well would make it seal okay. I should have cleaned it and started over but I was running short on time. Well, "pay me now or pay me later..."
Fast forward to last week, ... I was under the car changing the oil when I noticed a swath of exhaust soot on the back of the compressor housing. I assumed that the exhaust shim *might* not have sealed so well after all and had a small leak. I ordered a new shim from Jegs and just went out to take off the old shim and put on the new one. Ugh.. well...
My boost should come on a lot better with the new gasket.
Old Aug 24, 2013 | 06:23 PM
97WS6SCharged's Avatar
Re: Burnt T4 Shim gasket...
It didn't have an aluminum shim/gasket?
Old Aug 24, 2013 | 07:54 PM
DirtyDaveW's Avatar
the shim you see in the picture is the shim that came with it.
Old Aug 25, 2013 | 09:08 AM
Comp makes them in stainless. T3 up to a T6
Comp Turbo - Clamps
blac94Z
Nov 4, 2015 01:59 PM
ZXXVIII
Sep 1, 2015 10:13 PM
dolfan324
Jul 17, 2015 10:34 PM
achipfef
May 5, 2015 10:20 AM
1994TransAm
Jan 31, 2003 04:22 PM
