build my bottom end for 800rwhp
Old Mar 9, 2005 | 09:38 AM
  #16
turbo camaro's Avatar
Re: build my bottom end for 800rwhp
Originally Posted by LT1RX7
Time to start building my car for this race season. Been getting alot of suggestions on how I should build my bottom end so I just wanted to hear what you guys think I should buy.
To make things simple, I was thinking of getting these
http://cgi.ebay.com/ebaymotors/ws/eB...category=46098
and these
http://cgi.ebay.com/ebaymotors/ws/eB...category=33620
Probably would change the rods to Eagle H-beams
Do you think this kit will handle what I'm looking for? I mean, I'm not looking for too much. It's only going to see 2K miles a year tops. Going to run a T88, stock ported heads w/ 2.02/1.60 valves.
What do you think guys? Should I think more expensive or should these do?
whats up man will tell me tell you a little about me i run a twin turbo 80 camaro.friends off are doc.z twin turbo 70 camaro best time to date 7.90 gm block eagle crankshaft eagle h beam rods trw pistons.red nove seen in hot rod pump gas drags eagle crank eagle rods dart little m block.best time to date 8.9 pump gas at 18 pounds.found a real good place to get parts .cmc motorsports i get most of my stuf in less then a week.i just got a eagle crank from then 4340-nontwist forged steal for $488.as for the block if it is a 2 bolt block you can go with splade caps but you will run into water drilling the hole so you will have to seal the outer bolt's.if its a 4 bolt block go with the billet caps all 5.you will have to have the motor line honed so let the shop also do the balance gob.
Old Mar 10, 2005 | 03:15 AM
  #17
LT1RX7's Avatar
Thanks guys, I just ordered my shortblock from HPE. Had no time to wait From what I was told, I should have it here in about 3 weeks.
Old Mar 10, 2005 | 06:49 PM
  #18
atljar's Avatar
Hardest post EVER to read above. Geeeeeze.
Old Mar 11, 2005 | 04:46 AM
  #19
SMOKNZ's Avatar
You got that right. Just remember kids, CRACK KILLS!
Victor Lamb
Aug 26, 2017 02:52 PM
HarleyZ28
Oct 5, 2015 06:23 AM
Killer94z
Jan 13, 2015 12:06 PM
Collector Car
Jan 5, 2015 10:58 AM
