Barry grant fuel pump
Im looking for a fuel pump that will handle 700rw. Im currently looking at a Bary Grant fuel pump part#BGI-170042. it says that it will support 2,000hp and pumps 1000lb/hr@60psi. One of the things it says that it has to have is a EFI bypass regulator. Now if im right, that just an adjustable fuel pressure regulator right?.
I considered running an Aeromotive but Im just not to comfortable with there reliability. So I thought I would spend the extra coin and get a quality fuel pump. i think this pump by it self should suffice correct?.
Originally posted by IDOXLR8
If you are looking to go with a big external pump then save yourself some time and headaches and go with a Weldon pump. I would also highly recommend a voltage regulator box.
Originally posted by MEAN LT1
Hmmmm, thanks for the reply, what are the differences between the two. What part number are you running?
I am not running a Weldon pump on my setup. I am running twin internal pumps. I unfortunately do not have any part numbers for you. I do not have any experience with Barry Grant stuff so I cannot comment but my buddy installed a Weldon pump on a GN and can say that it is a nice piece and works extremely well. The only downfall is that is sounds like a weed wacker.
Thats right, you did tell me you were running twin intank fuel pumps. I might have to consider this an option as well but if I can get away with just running one fuel pump to supply all the fuel the motor needs that would be cool.
-Fuel tank needs to be sumped
-Braided fuel lines, fittings, and fuel filters
-Fuel rails need to be modified
-etc...........
The only thing about running an big external pump is that is gets extremely expensive.
-etc...........
-etc...........
So are you saying that your still running the factory fuel lines from the tank to the fue rail?. If so I wonder if that could be hurting hp in any kind of way?. But I guess as long as fp is stable it shouldnt be hurting anything right?.
10-31-2016 11:09 AM
JasonD
08-23-2010 03:14 PM
