Anyone else have their intake elbow blow off?
Old Dec 21, 2005 | 03:37 PM
  #16
Jeff 96 SS's Avatar
Re: Anyone else have their intake elbow blow off?
Pics sent
Jeff
96 SS BLOWN
96 TA 396 D1
Old Dec 21, 2005 | 11:37 PM
  #17
Procharged94Lt1's Avatar
Any chance you could send them to
Bigblkpjcrusher@yahoo.com
Havin the same problem occasionally and a while and wish to solve it once and for all!!
Old Dec 22, 2005 | 12:18 AM
  #18
Blown_Red_97z's Avatar
On my car, just the tube with the bypass valve popped off once, causing my car to throw a code and run really rich. Quick pop of the hood, and I was back in business, but I'll admit it scared the **** out of me at first.
Old Dec 23, 2005 | 12:15 AM
  #19
BADST95's Avatar
Thumbs up Re: Anyone else have their intake elbow blow off?
Originally Posted by Jeff 96 SS
When you run big boost their is no chance of keeping that thing on even with t-bolt clamps. I made a bracket also but it mounts to the radiator shroud and basicly keeps pressure on the elbow to hold it in place. I can send pics to those that are interested.
Jeff
96 SS BLOWN
96 TA 396 D1
Really? 388 stroker, ProCharger F1 (22 psi), using worm clamps on the entire system and I have yet to blow off a tube. I also welded a bead around the tubes so that the tubes don't slip off. The key is to re-tighten the clamps after running the car for a while. I check my clamps every now and then just to make sure and they don't get loose.
Old Dec 23, 2005 | 02:45 AM
  #20
JordonMusser's Avatar
West South Central Moderator / Special Guest
yup, fab a brace to hold the 2 pieces together. normal stuff!!!
Old Dec 23, 2005 | 06:15 AM
  #21
Jeff 96 SS's Avatar
There are two main reasons you don't have this problem.
1. You don't have an lt1 throttle body your clamp is able to provide clamping force on almost 100% of of your TB. The lt1 throttle body is a different animal and a clamp can only provide true clamping force on about 30%.
2.Your piping does not make a 90-degree turn just before entering the throttle body. The turns create a good bit of force that actually tries ripping the pipe off the throttle body.
That is assuming the picture is of your engine compartment.
Jeff
96 SS BLOWN
96 TA 396 D1
Old Dec 23, 2005 | 07:41 AM
  #22
LittleRedZ's Avatar
You all might want to try some Hair Spray before you go and try to make a bracket its worth a shot. A 3dollar can did it for me 17-18#s on a regular style clamps. It used to blow all kinds off connections off on my twin set up till one day i took every connection apart sprayed it with Hair Spray and reconected back up. Hair spray works like glue, so whenever you have to take connections back apart it gives you a little fight.
Old Dec 23, 2005 | 11:44 AM
  #23
BADST95's Avatar
Jeff
96 SS BLOWN
96 TA 396 D1
Sorry... I think 22 psi throws your "logic" right out the window.
Old Dec 23, 2005 | 12:02 PM
  #24
SiCk PuPpY's Avatar
For a quicker fix, you could also safety wire it to the T.B.
Old Dec 23, 2005 | 12:56 PM
  #25
Jeff 96 SS's Avatar
"Sorry... I think 22 psi throws your "logic" right out the window"
It’s obvious you need a physics lesson!
Hold three fingers out parallel to each other and wrap a rubber band around them until it gets a little tight. Now pull on the top or the bottom not very tight is it now pull on the sides that’s pretty damn tight isn’t it Hmmm. Now take one finger and wrap a rubber band around it until it’s tight pull on it anywhere Hmm it’s tight no matter where you pull it. That is the difference! Now I would suggest you take the rubber band off your finger as it will cut off the blood flow For the second lesson take a straw and blow through it ok air in one side and out the other Hmmm now bend that straw and blow through it wow what is happening.
The 22 psi has little to do with it your setup does not have the same piping inefficiencies as most of ours. By the way I also run 22psi I would give you a cookie but I just ate it
I’m just trying to help people what are you doing in this thread?
Jeff
96 SS BLOWN
96 TA 396 D1
Old Dec 23, 2005 | 05:49 PM
  #26
BADST95's Avatar
Jeff
96 SS BLOWN
96 TA 396 D1
Hmmm... the 2 cars that I built with almost identical motors using the stock LT1 intake, ProCharger F1 (22 psi), making almost 800 rwhp don't blow off the tubes. I guess it's how I installed it. It must be magic.
One of these cars that I built ran a 9.54 and the tube never came off during the run.
I am trying to help people as well. I am just showing them that worm clamps can work.
Old Dec 24, 2005 | 02:40 PM
  #27
Jeff 96 SS's Avatar
I'll be racing at indy (IRP) next year May 18-20th I would like to see some of your magic cars so bring them on out. www.fbody-event.org The web site isn't up to date we are in Indy this year if you want some help getting signed up let me know. This event is tons of fun and I would like to see your car so come on out thats not far from you.
Jeff
96 SS BLOWN
96 TA 396 D1
Old Dec 24, 2005 | 03:28 PM
  #28
BADST95's Avatar
Wink Re: Anyone else have their intake elbow blow off?
Jeff
96 SS BLOWN
96 TA 396 D1
Thanks for the offer, but I'm not interested in going to Indy to prove myself.
mightymouse383
Jul 20, 2016 07:34 AM
DirtyDaveW
Mar 15, 2015 07:01 PM
RedLineRev
Jan 23, 2003 03:51 PM
slothgrant
Aug 22, 2002 03:01 PM
