Another half baked FI idea
Old Apr 10, 2005 | 06:38 PM
Beyonce Knowles's Avatar
Once again, this is border line lounge material, but...
Would it be pobbile to rig up am "on/off" turbo system by using a system electric cutouts that would could open and close to either route air through a turbo system or bypass the whole thing and run na?
http://community.webshots.com/photo/...9355754UjmcSf#
Old Apr 10, 2005 | 11:35 PM
slimdawson's Avatar
Re: Another half baked FI idea
Yes. Almost anything is possible.
Old Apr 11, 2005 | 03:34 PM
Leedogg 96TA's Avatar
sure you could...but why? It isn't like a turbo hurts you when you aren't under hard acceleration.
Old Apr 11, 2005 | 03:43 PM
BlownF1's Avatar
You'd have to do something for tuning on the fly too wouldn't you?
I also fail to understand why anyone would want to...but the thoughts/discussion is interesting.
Old Apr 11, 2005 | 03:44 PM
tryintogofast's Avatar
Not to mention your injectors/timing would be setup for when the car was under boost. It would run like crappy rich unless you had that toggle switch change the tune at the same time.
Mikey
Old Apr 12, 2005 | 06:34 AM
slimdawson's Avatar
If you had an fmu setup, it would be a little closer on and off boost. Timing control would take care of ignition.
I still don't see the point though.
Old Apr 13, 2005 | 11:57 AM
mongse_1's Avatar
If you want an on/off switch, put the hose to it instead of a turbo.
Kempster
Jul 7, 2020 11:00 AM
kolbaso
May 21, 2015 01:49 PM
94Z28LS1toLT1
Jan 15, 2015 07:18 PM
Perry93TransAm
Aug 20, 2002 11:23 PM
