in 95 camaro lt1 w air buildup
Old Apr 19, 2008 | 11:18 AM
  #16
reamo04's Avatar
1) yes, you can pull oil from the aux. port above the filter
2) you can do that, if you do, you will need an oil/water seperator, can be had for like $5.
Your other option for the PCV vent, is to run the breather tube off the passenger side VC into a "breather tank". like this http://store.summitracing.com/partde...5&autoview=sku
Old Apr 19, 2008 | 08:17 PM
  #17
akafred's Avatar
i want to pull oil from the back of the engine behind the intake mainfold. there is a 1/8" fitting that the oil sender goes into. i want to add a t and run the oil sender and the turbos.
also i think that i may need a smaller catch can.
Old Apr 20, 2008 | 03:16 PM
  #18
97ChameleonTA's Avatar
Moderator
Yes, you can pull oil from there as well. Just add a T-fitting, or in your case, 2 T-fittings.
Old Apr 21, 2008 | 05:36 PM
  #19
akafred's Avatar
notched rad support today
Old Apr 21, 2008 | 05:53 PM
  #20
SMOKNZ's Avatar
Nice work!, what kind of hood latch is that? any info?
Bill
Old Apr 24, 2008 | 08:19 PM
  #21
akafred's Avatar
here is one very similar to the one i used. it will hold 750lbs should be ok.
http://mooreindhardware.thomasnet.co...nid=&appid=124
Old Apr 25, 2008 | 08:19 AM
  #22
Tricked-Out-Toy's Avatar
Looks great! do you plan on painting or polishing the piping?
Old Apr 25, 2008 | 04:40 PM
  #23
4SFEDZ's Avatar
wow good work!!!!!
Old Apr 26, 2008 | 10:48 AM
  #24
96SilverRam's Avatar
Wow, very nice work! Great job on building the headers and the general fab-work. More pics & progress
Old Apr 26, 2008 | 11:53 AM
  #25
reamo04's Avatar
you should ditch that MAF and go speed density with a 2 bar map tune
Old Apr 26, 2008 | 12:32 PM
  #26
akafred's Avatar
for now its staying... i have a piece of pipe thou that will be used to removely maf if i do a 2 bar tune.. for now with this stock motor it will only see 4-5 psi with maf
mid summer i am going to start a engine build and it will go 2 bar no maf.
Old May 6, 2008 | 08:31 PM
  #27
akafred's Avatar
still have to feed turbos oil and drain
build exhaust
run heater hoses
bov and wastegate boost and vacume lines
drain the 3 yr old gas from the tank
make new rad overflow
make new power steering tank
make new washer fluid tank
drop sway bar ~2"
re plum brake lines
Old May 11, 2008 | 07:40 PM
  #28
akafred's Avatar
build exhaust
run heater hoses
drop sway bar ~2"
re plum brake lines
Old Jun 7, 2008 | 07:28 PM
  #29
akafred's Avatar
car fired up today for the first time in 4 years. after hearing how quiet it is with just 15" of down pipe i have decided to not run mufflers.. i will just run cats. car had no coolant in it so i only let it run for a bit. also i never hooked up the charge tube to the throttle body as it was still programed with tons of timing.. i more or less wanted to see if this motor was any good..
i need to re route my one rad hose and am looking for some sch20 pipe and weld on elbows. does any one know where i can get this? or even better 1.25 od s/s tube and bends.
Old Jun 7, 2008 | 07:33 PM
  #30
akafred's Avatar
does anyone have a tune that i can start with? car is 95 6 speed..
