in 95 camaro lt1 w air buildup
1) yes, you can pull oil from the aux. port above the filter
2) you can do that, if you do, you will need an oil/water seperator, can be had for like $5.
Your other option for the PCV vent, is to run the breather tube off the passenger side VC into a "breather tank". like this http://store.summitracing.com/partde...5&autoview=sku
i want to pull oil from the back of the engine behind the intake mainfold. there is a 1/8" fitting that the oil sender goes into. i want to add a t and run the oil sender and the turbos.
also i think that i may need a smaller catch can.
Yes, you can pull oil from there as well. Just add a T-fitting, or in your case, 2 T-fittings.
here is one very similar to the one i used. it will hold 750lbs should be ok.
http://mooreindhardware.thomasnet.co...nid=&appid=124
for now its staying... i have a piece of pipe thou that will be used to removely maf if i do a 2 bar tune.. for now with this stock motor it will only see 4-5 psi with maf
mid summer i am going to start a engine build and it will go 2 bar no maf.
car fired up today for the first time in 4 years. after hearing how quiet it is with just 15" of down pipe i have decided to not run mufflers.. i will just run cats. car had no coolant in it so i only let it run for a bit. also i never hooked up the charge tube to the throttle body as it was still programed with tons of timing.. i more or less wanted to see if this motor was any good..
i need to re route my one rad hose and am looking for some sch20 pipe and weld on elbows. does any one know where i can get this? or even better 1.25 od s/s tube and bends.
