in 95 camaro lt1 w air buildup
Old Apr 6, 2008 | 05:20 PM
akafred's Avatar
i started this build a couple years ago but havent had much time to work on it. getting back into it now that that i have some more time.
pass side header, moslty done still needs the colector welded. i might take it to my friends house as its a pita to weld up the collector with the tig
dirver side same story as the pass side.
3" drivers down pipe
my ****ty intercooler welds and new hood latch. still working on the saftey catch. i plan on running 2 pipes out of the top pf the intercooler to the throttle body. i will have to notch and box the rad support to do this.
new aluminum fan monts. i had to lower the fans to fit the dual 3" down pipes. i also had to lower the swaybar 2" but it should still be higher than the k member..
Old Apr 6, 2008 | 05:21 PM
akafred's Avatar
more work done today
headers off the car
Old Apr 6, 2008 | 09:24 PM
crazycat's Avatar
I am working on fabbing up own turbo set up also. Looks like yours is coming along nice. I wanted to do twins but but it didnt work out for me. Nice job on the headers ! What size turbos are you running ?
Old Apr 7, 2008 | 05:21 AM
akafred's Avatar
60-1's
.81 exhaust housings
Old Apr 7, 2008 | 11:17 AM
reamo04's Avatar
definately nice lookin headers.
Old Apr 7, 2008 | 11:36 PM
TasTe GOOD's Avatar
loving your build man, keep up the posts
Old Apr 8, 2008 | 12:10 AM
Sparkz28ss's Avatar
nice lookin hot parts..
dig the setup
Old Apr 12, 2008 | 09:51 PM
akafred's Avatar
just waiting on parts, and my argon ran out. got a new bottle today and made some wastegate flanges today.
Old Apr 15, 2008 | 01:33 PM
Tricked-Out-Toy's Avatar
Looks awesome! what do you plan on doing to the engine?
Old Apr 15, 2008 | 08:38 PM
akafred's Avatar
right now its stock probaly under 5lbs.. i have another engine that will be built mid summer. probably try to get 3mo out of the stocker hopefully i dont pop it. doesnt really matter if i do pop it just would be a bit of a waste as its a low k motor.
my new engine will be a 383.
heads i have ported stockers that made the numbers in sig.
je 31cc dish pistons
eagle forged 3.75
eagle 5.7 H beams (probably get upgraded bolts)
eagle 4 bolt mains
i have arp head bolts may get studs
probably get some high z 79lb injectors and twin intake pumps
Old Apr 16, 2008 | 11:23 AM
jammer94's Avatar
who fabbed up them headers for you?
Old Apr 16, 2008 | 06:46 PM
akafred's Avatar
i fabbed them up..
Old Apr 17, 2008 | 07:48 PM
akafred's Avatar
made new hood latch, pop and saftey catch today
Old Apr 18, 2008 | 03:59 PM
akafred's Avatar
my parts come in today...
Old Apr 19, 2008 | 09:33 AM
akafred's Avatar
can i pull oil from the back of the engine where the presure sender is?
also will i be able to hook my pcv breather into my turbo inlet? will i need a oil separator?
