396 compression
Old Feb 5, 2004 | 09:09 PM
1984camaroz28's Avatar
396 compression
what would be an ideal compression to run for a 396 stroker. I wanna run 10lbs of boost what would be a good compression ratio? I wana be able to run on 93octan
Old Feb 6, 2004 | 03:29 AM
rskrause's Avatar
Moderator
Re: 396 compression
While the cam will have an impact on optimum CR, I'd say ~8.5:1 to run with 93 and boost. My setup for this year is ~7.8:1, but I am running more boost.
Rich Krause
Old Feb 6, 2004 | 08:08 AM
whould i be fine with not O-ringing the block and just use a good cooper gasget
Old Feb 6, 2004 | 08:15 AM
rskrause's Avatar
Moderator
You don't need copper, in fact, you don't want it. It really is a race car gasket, as far as I am concerned due to a tendency to seep (leak). Most people do fine with the FelPro #1074. I used the FP for four years with no problkems. I am going to try the Cometic this year, but a FelPro gasket is fine and less $$$.
Rich Krause
Old Feb 6, 2004 | 08:39 AM
MEAN LT1's Avatar
Re: Re: 396 compression
Rich Krause
Why so low on the compression if hes only running 10psi of boost. Wouldnt he be ok with say 9.2:1 running 93pump
Old Feb 6, 2004 | 09:28 AM
ltlhomer's Avatar
I think Rich is giving him a little room for more boost in case he wants to throw the bigger pulley on there.
Old Feb 6, 2004 | 09:54 AM
IDOXLR8's Avatar
You mean smaller pulley
Old Feb 6, 2004 | 08:13 PM
ltlhomer's Avatar
Always one in the crowd.
Quickss96
Jan 29, 2016 05:56 PM
surreybrad
Sep 29, 2015 09:00 PM
Daluchman1974
Sep 11, 2015 06:12 AM
13qtr
Jul 19, 2015 05:30 PM
pimpss96
Feb 12, 2015 01:28 PM
