2 bar map sensor -will it work?
Old Sep 10, 2004 | 09:50 AM
  #16
Roadie's Avatar
Re: 2 bar map sensor -will it work?
Originally Posted by The Highlander
Roadie... when you change the boost it is often times better to re-tune. there is nothing like a tune for all conditions... and since you don't have a MAP PE table, well... you will need to deal with your fueling again.
I agree on the fuelling bit, but that's why I said "as long as boost fuelling is also covered". It's a lot quicker for me to have a good baseline and tweak the superfueller on the dyno than it is to retune a few times on the dyno.
If money were no object, I'd not worry about dyno time costing $$, ditch the stock pcm and go with FAST or DFI, and probably have a whole lot more power.
Old Sep 10, 2004 | 10:15 AM
  #17
Highlander's Avatar
You know... even if $ where no object, i would still keep the stock pcm.
Old Sep 12, 2004 | 06:40 PM
  #18
arnie's Avatar
Considering the number of 'extras' included in the oem pcm code, it is tough not to prefer the oem item. With the hundreds (maybe thousands) of man hours put into the design (complexity and thoroughness) of the oem pcm, it becomes a very formidable (nearly impossible) task for aftermarket to compete, what with the budget oem sets aside, for their pcm development.
Although, if the vehicle is to be driven zero miles on the street, the playing field becomes more favorable for the aftermarket.
Old Sep 29, 2004 | 04:42 AM
  #19
Highlander's Avatar
after checking that 2barfile that floated around (just cal changes to use the 2bar) i was thinking, why not lower the injector constant to 1/2 and scale VE for those running speed density???? So VE can actually go higher than 100%?
HectorM52
Jul 30, 2017 11:46 AM
DirtyDaveW
Dec 1, 2016 05:37 PM
Amshnock
14
Jan 18, 2015 11:47 AM
siguy
Nov 27, 2014 10:07 AM
