What headers are legal in ca.
Old Jan 2, 2007 | 06:57 PM
  #16
paul463's Avatar
Injuneer, two questions come to mind. Were they the SLP's that your friend was having heat issues with? Would ceramic coating have helped? Seems I read here a week or so back that the coating can give a 40% reduction of underhood temps. One more question. How did the extrude honed manifolds compare to the headers? Paul
Old Jan 2, 2007 | 09:59 PM
  #17
My buddy with the 97 Z28 had a set of AS&M dual-cat headers. They were HPC cera-metallic coated. That was my point in explaining that AS&M made the dual-cat headers, but stopped making them because they had so many heat problems.
I don't know what kind of HP gains the extrude honed manifolds provided. The car was limited to very basic boltons.
Old Jan 16, 2007 | 03:42 PM
  #18
corbraeater's Avatar
i have a set of pace-setter mid's they are for 96-97 LT1 w/ dual cats, my 95 has the same set-up since it's a cali car. The CARB number is the part number weld to the headers, i just pass smog a few months back with them on
Old Jan 16, 2007 | 08:30 PM
  #19
axldrivesz28's's Avatar
isn't it different for 98-02 though??..i have a 98 z and i haven't seen a set of mid tubes for my car...
Old Jan 16, 2007 | 08:34 PM
  #20
2000GTP's Avatar
MAC makes a set for the 98-02s.
Old Jan 16, 2007 | 08:44 PM
  #21
oh yea...just saw that...thanks...pacesetter does make them for the 98's too...just checked...are the mid tubes better than the oem shorties??...will the cat have to be moved for fitment of any midtube??..hp gains??
Old Sep 30, 2007 | 12:18 AM
  #22
JFR's Avatar
JFR
Have a 1995 z28 5.7 lt1, it is federal, only one cat,i'm in Cal. I am wondering if I can remove, or make it so I can remove the heat shields on the exhause manifolds. It sure would make it easier to remove the heat shields first and then remove or install the headers. I'm guessing you have to run with the heat shields intact, i have oem headers.
It would probably save hours even changing plugs with those heat shields off.
I have already moved my electric air pump, and got rid of the pipes, and gone to hose over the top of engine, away from the heat.
any comments welcome.
Dzmaro
May 7, 2015 09:33 AM
NewsBot
Apr 10, 2015 03:10 PM
Z28amustangklr
Middle Atlantic
Mar 28, 2015 03:08 PM
Firemechanic
Parts Wanted
Dec 14, 2014 10:22 AM
