Question: Slip fit collectors (primary side)
Old Aug 2, 2010 | 10:22 AM
razor02097's Avatar
Question Question: Slip fit collectors (primary side)
I have a dumb question. What do I do to mount the collector to the primaries? It is a slip fit on the 4 primary tubes so welding will be pretty much impossible... it didn't come with any instructions so does it just slip on and that is it or what?
Here is a photo of what I have...
Old Aug 3, 2010 | 04:02 AM
MikeGyver's Avatar
Why would welding be impossible?
Old Aug 3, 2010 | 05:55 AM
razor02097's Avatar
I wouldn't be able to reach the inside of the collector.
Old Aug 3, 2010 | 07:21 AM
razor02097's Avatar
Most info I can find is about slip fit primary tubes.
http://www.jalopyjournal.com/forum/s...d.php?t=120625
https://www.camaroz28.com/forums/arc...p/t-81926.html
With the collector would sealant be necessary? I just want to know if I need to secure them on the headers. They are an awful tight fit so using silicone or glue might be a big endeavor.
Old Aug 5, 2010 | 08:50 AM
razor02097's Avatar
Anyone?
Old Aug 10, 2010 | 08:37 AM
razor02097's Avatar
Still need an answer....
ECHO....ECHO....ECHO....ECHO....echo....echo....
Old Aug 11, 2010 | 07:14 AM
Stainless Works's Avatar
There are usually A/B tabs that are welded to the collector and primary. You then slip the collector over the primary and bolt the two a/b tabs together.
You should be able to see what I'm talking about in these two pictures:
Realistically you cannot get a 100% leak free seal with that style collector. In order to get a full 100% welded collector you would have to go with a formed collector with a welded diamond that connects the 4 primary's. We sell them and can be seen here:
http://www.stainlessworks.net/cart/i...p?cPath=95_127
-Anthony
Old Aug 11, 2010 | 07:27 AM
razor02097's Avatar
Ah ha! Thank you!
F'n1996Z28SS
Aug 23, 2023 11:19 PM
Keenan
Jan 19, 2023 12:24 PM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
Jul 4, 2005 05:00 PM
