Kook LTs and oil filter too close
Old Aug 1, 2010 | 07:57 AM
TitoPR221's Avatar
Motor is out of the car. I installed the headers checking for fitment. The oil filter would be impossible to replace with the headers being so close.
I am considering a remote filter relocation. Any ideas or suggestions?
Old Aug 1, 2010 | 08:18 AM
TitoPR221's Avatar
Interference between oil filter and Kook LTs
Any suggestions on which filter to use that will allow filter changes with Kook LTs? Do I need a remote filter?
Old Aug 1, 2010 | 11:59 AM
joeSS97's Avatar
Mobil 1 - M1 111 . Wix has one that I dont recalll the number off hand.
Old Aug 8, 2010 | 08:01 PM
joeSS97's Avatar
I responded to your thread in the LT1 section and will here too for the searchers. The Mobil one number 111 is as big as you can get in there. A bit of a PITA to change, but doable.
Old Aug 9, 2010 | 09:19 PM
speedracer2j's Avatar
Your car dosent have factory oil cooler does it? If so, it has to go, and replace it with the normal housing, and remove the cooler lines. Had to do it with mine, now im running the short fram filter, dont remember the number, but its really do'able, only issue is make sure you remove the oil level sensor
Old Aug 10, 2010 | 09:01 PM
TitoPR221's Avatar
Thanks, I found that the ACDelco PF454F is also the same size as the Mobil1. I preferred the Mobil1 1-111 as you mention, much more filter material (weight).
The Fram XC-30 (someone posted in another thread) is too long by the way.
Old Aug 10, 2010 | 09:03 PM
TitoPR221's Avatar
No oil cooler, no problem, found the right size....Will be a PITA to replace, but the performance will be worth it....
Old Aug 10, 2010 | 09:07 PM
TitoPR221's Avatar
Thanks, I read your response in the other thread at the exhaust section.
Old Aug 10, 2010 | 10:16 PM
Merging cross-posts.
Old Aug 11, 2010 | 06:28 PM
TitoPR221's Avatar
Thanks Fred.....
HectorM52
Jul 30, 2017 11:46 AM
Dmonty
Jun 2, 2015 11:19 PM
Jul 4, 2005 05:00 PM
97 RedSS
Jun 10, 2003 07:58 PM
Darth Xed
13
Jul 22, 2002 12:45 PM
