Non-emission lt header install 96z28 questions
Old Jul 27, 2009 | 10:21 AM
manfire1987's Avatar
Ok the headers i have are non emission long tubes hooker comp. To be specific. Ok my question is since the headers DO NOT HAVE have the e.g.r or a.i.r. Hook ups do i have to take of my smog pump??? I am not worried about smog issues.. So if i do take of the smog pump i loose that pulley so now i have to get a different belt correct??? How does this work my car is a 1996 lt1-z28 6 speed can some one give me the help on what all needs to be done for this install to make it be done right i keep hearing different stories and before i start this pain in the *** job i want to go into knowing as much as i can!!! Any help would be great please either message me on here or e mail at manfire1987@yahoo.com thanks very much
Old Jul 27, 2009 | 08:45 PM
Your smog pump does not have a "pulley" and is not driven by the serpentine belt. It runs on an electric motor.
You can leave the pump bolted to the front/driver's side of the engine, or you can remove it. You will need to plug the connection on the air intake ducting for the hose that supplies air to the AIR pump. Your 96 may also have have the smog recall done on it, in which case you would have an extra vacuum line "tee'd" in the vacuum lines on the driver's side of the engine. That tee would have to be removed or the nipple capped.
http://shbox.com/1/air_pump_recall.jpg
You also have to plug up the connection on the back of the intake manfold where the corrugated riser tube for the exhaust gas connected. If you remove the EGR valve, you need a blockoff plate for that. If you remove the EGR vacuum solenoid, you need to plug the vacuum nipple on the driver's side of the intake manifold.
http://shbox.com/1/egr1.jpg
Then you need to have the EGR and AIR codes programmed out of the PCM.
Noenav
Mar 1, 2019 07:38 AM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
Jul 4, 2005 05:00 PM
GigaMp3z
Feb 20, 2003 02:57 PM
