(LT1) Header install tips
Old Jan 18, 2007 | 03:05 PM
  #16
Lookn4MySS's Avatar
Prepare to bust your knuckles up and use air tools.
Old Jan 18, 2007 | 03:16 PM
  #17
JAG05's Avatar
Can you run the stock size wires over the value cover or do you need longer wires to do this?
Old Jan 18, 2007 | 03:20 PM
  #18
2tight's Avatar
I think you need longer one's here is a link take a look
http://www.thunderracing.com/catalog...vid=4&pcid=104
Old Jan 18, 2007 | 03:22 PM
  #19
camarozz95's Avatar
I actually bought the Taylor Over the valve cover kit and it ended up being back ordered so when I did the install I just used the stock wires with stock routing and believe it or not have not had a problem none of the wires even come close to the headers.
I still do plan on putting the new wires in at some point just haven't had the time since school restarted
Old Jan 18, 2007 | 03:23 PM
  #20
2000GTP's Avatar
Either will work, however, if you are going to use the stock routing setup, you may have to use come cable ties to secure some of the wires away from the header primaries.
Old Jan 18, 2007 | 03:26 PM
  #21
2tight's Avatar
Would those be plastic cable ties?
Old Jan 18, 2007 | 03:29 PM
  #22
2000GTP's Avatar
Yes.
Old Jan 18, 2007 | 05:07 PM
  #23
Critter's Avatar
Hey what part of Texas you in? if you are around DFW please tell me who is doing your Header install.
where you live?
Old Jan 21, 2007 | 12:10 AM
  #24
94jetpilot's Avatar
install location for 300 bucks
here in san antonio texas, a place called alamo performance, talk to roy in installation,does them all the time i hear, real good at it! hope it helps.
SpeedJunkee
Dec 9, 2014 10:17 PM
thenewkid
Nov 27, 2014 09:41 AM
Jul 4, 2005 05:00 PM
GigaMp3z
Feb 20, 2003 02:57 PM
