(LT1) Header install tips
Im considering installing a set of BBK mid length headers on my 97 Z28 with a M6 this weekend. Wondering if anyone has any install tricks or tips or maybe a walkthrough? Ive installed shorty headers on a third get before and had to remove a valve cover and alternator to get them to slide in. Also, any tips to get the manifolds off a little easier? Any help is much appreciated,
Thanks, Danny :D |
Re: Header install tips
take your time
make sure you have penetrating oil and anti-sieze ready Be careful to take the dipstick out, you dont want to break it off, mine went into the pan about 6 inches, so its a lot of pulling I put some pliars on the bracket and twisted while pulling and it came out quick Put it in the freezer to put it back in, it works wonders for the steering linkage, use a screwdriver to pry it out, and possibly a hammer to help it go back in Gap your spark plugs the night before, you dont want to be doing precision work when your all tired and greasy Good luck |
I took the alternator, the dipstick, and the starter off to install my mid's. They will go in from underneath, not up top. Just make sure you soak the stock manifold bolts down with penetrating oil real good the night before. It should go smooth, mine did, not nearly as bad as everybody made it out to be.
patience, the most important of all. When things feel like they are getting bad and the attitude starts to go south, just walk away and take a little break. These cars can be very frustrating to work on till you get the "order" of how things are done. It is worth the hassle, trust me.
extend and relocate the wires that run down the pass. side inner fender well. They will burn if you dont causing your car to not start. Two of the wires go to the starter.
Steve |
anyone done this to a automatic z? if so what kind of time frame am i looking at?
It depends on your skill level and how smoothly the job goes... you can be done in a day or it can take a few days.
thanks!
theyre on their way now, but i found a shop here locally thats doin it for me for 300 bucks, a performance shop that has done these time and time again,what kind of wires would be recommended? any help would be appreciated.
new to this site,...but old to my share of experiences with my z., gone through it all!!!
Originally Posted by 94jetpilot
(Post 4350906)
Buy a good set of gaskets and bolts instead of using the paper gaskets that come with the headers. :)
Here's a header install article that will give you a few tips/tricks. I wrote it about 6 yrs ago. http://lt1howto.com/articles/flpinstall.htm
use copper gaskets!!!!!! summit sells them for 25 bucks IT IS WORTH IT!
Mechanix gloves!
Hey what part of Texas you in? if you are around DFW please tell me who is doing your Header install.
