Hooker vs Pace Setter long tubes - pics inside...
Old Jan 16, 2007 | 10:46 AM
  #31
Brent94Z's Avatar
Super Moderator
Originally Posted by CamaroRacing12
so brent if u didnt have either of these headers, and u saw this post....which ones would u buy?..... i am all for the pacesetters except for the pics of the collectors kinda make me second guess my decision....also how hard is it to bolt a 3" exhaust to those slip fit collectors????
Right now I actually don't have a strong opinion as to which one is better than the other mainly because I have no dyno numbers to accurately compare the performance difference. Right now if I had to buy one set or the other I'd probably buy the one I could get the best deal on
As for the slip fit... that's not really an issue IMO. I've seen no problems with them on my bud's car. Here are some pics...
http://www.brentfranker.com/gallery/album107?page=4
Old Jan 16, 2007 | 10:50 AM
  #32
CamaroRacing12's Avatar
So all he did was attach them with those clamps?.... 3" collector to 3" piping with just those clamps holding them together with no problems? sounds great...sounds like what im gonnna do...
btw i havent got the vinyls i got form u on the car yet.....im waiting for the spring...but once i do i will def send some pics ur way....
Old Jan 16, 2007 | 10:55 AM
  #33
Brent94Z's Avatar
Super Moderator
No... it is an actual slip fit. They overlay by an inch or two and then the clamp goes over this area. When you use an impact gun to tighten the bolts these seal up very good
http://www.brentfranker.com/gallery/...500_IMG?full=1
Sounds good on the pics. Thanks!
Old Jan 16, 2007 | 01:46 PM
  #34
ooo so the collectors a lil larger then 3"....so the piping can slip right in...then u clamp it down....sorry its just hard getting a visual of it.
Old Jan 16, 2007 | 03:22 PM
  #35
Projectz28's Avatar
Moderator
other way around. The pipe is slightly larger than the collector to go over the collector and clamp down.
Old Jan 16, 2007 | 03:45 PM
  #36
so the collectors rn't exactly 3"?
Old Jan 16, 2007 | 04:15 PM
  #37
Projectz28's Avatar
Moderator
the collector is 3", but the pipe that goes over it is slightly larger. Its done with a pipe expander so one pipe can be slipped over the other.
Old Jan 16, 2007 | 06:08 PM
  #38
Jared 3870's Avatar
The collector in the pacesetters would be 3" OD (outer diameter, measured from outside edge of pipe) and a universal X-pipe will have a 3" ID (inner diameter, measured from inside edges of pipe), allowing them to slip together.
Old Jan 16, 2007 | 06:10 PM
  #39
Projectz28's Avatar
Moderator
much better explanation than mine
Old Jan 16, 2007 | 09:25 PM
  #40
i hope ur right! if not i will bring my duals to my friend who will widen then on that machine he has at his shop...
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
ModdedNerd
Jan 1, 2015 10:56 AM
startingstock
Exhaust System
Dec 12, 2014 06:40 PM
