Exhaust Manifold Gasket Fitment
Old Apr 8, 2021 | 11:05 AM
1994-LT1-Eric's Avatar
Factory LT1 exhaust manifolds.
Felpro 1406 first image.
Remflex 2022 second image.
Why do the outboard bolt/stud holes not line up? Only the inboard 4 bolts go through the gasket?
I bought the remflex first because they crush up to 50% and seal a bit better than felpro. The fitment didn't line up with the outboard bolt holes on the manifold so I researched again and got felpro 1406 and same thing.
Correct sized gasket or do I need a different one for OEM manifolds?
Old Apr 8, 2021 | 06:27 PM
Re: Exhaust Manifold Gasket Fitment
Seems like only the inboard 4 bolts pass through the gasket. Seems to be sealed up good. We'll go through a few thermal cycles and see how it holds up.
Old Apr 8, 2021 | 07:13 PM
Risky.
Maybe ???
https://www.jegs.com/i/BBK+Performan...ABEgLHbvD_BwE#
Old Apr 8, 2021 | 07:18 PM
https://www.summitracing.com/parts/r...yABEgJEbfD_BwE
Old Apr 8, 2021 | 07:20 PM
Old Apr 8, 2021 | 07:51 PM
Damn, I didn't see the Remflex 2024s would extend out to the last holes. They've sealed up for now with no leaks. Worse case they end up leaking, I now can pull them off pretty easy if I have to now that I've done it once.
[edit] and they don't have to come all the way out just to replace gaskets.
Old Apr 9, 2021 | 12:01 AM
A leak there will screw up the O2 sensors.
Old Apr 9, 2021 | 08:17 AM
Yes, that's the reason why I pulled them to begin with - and ended up restoring the manifolds while I was at it. I ordered the 2024s. The 2022s aren't leaking, as of yet, but I'll be ready to R&R the gaskets if/when they do.
My hands are sore and don't wanna pull them back off today 🤣 I'm doing the ICM mod today.
CamaroFbody
Mar 29, 2010 07:57 AM
z28camaro1090
Oct 14, 2009 08:14 PM
mustangmuncher
Feb 21, 2005 08:47 PM
TrouserSnake
Apr 29, 2004 09:42 PM
Ry
Jun 18, 2002 06:17 PM
