exhaust manifold issue
Old Oct 7, 2009 | 05:50 PM
z28camaro1090's Avatar
I just replaced my exhaust manifold gasket because the driver side rear was leaking. I start the car up and it is still leaking! Whats the issue? and how can it be fixed?
Old Oct 7, 2009 | 07:01 PM
LearJet's Avatar
Replace them with a set of headers.
Old Oct 7, 2009 | 09:24 PM
sure you want to buy them for me?
Old Oct 7, 2009 | 10:11 PM
greenmachinedriver's Avatar
if you replaced the gasket correctly and it is still leaking you probably have a warped or cracked exhaust maifold. less likeley you could have a stripped bolt or bolt hole but you would have found that when you changed the gasket.
Old Oct 8, 2009 | 10:07 AM
Z28SORR's Avatar
Didn't leave any old gasket material stuck to the head? Also did you check the flatness of the surface, especially in the leak area?
Old Oct 8, 2009 | 10:12 AM
there wasnt any stuck gasket.. i think it might be warped. so theres no way of gettign around that besides new headers or something
Old Oct 8, 2009 | 11:25 PM
MikeGyver's Avatar
lmao yeah cuz headers always seal
You manifold is probably not flat or the bolts are bottoming out and not clamping hard enough.
Old Oct 9, 2009 | 05:45 PM
evilundisguised's Avatar
If it is warped, you can take it to a machine shop and have them mill it flat.
Old Oct 9, 2009 | 06:01 PM
yeah i also have real bad carbon build up on the cylinders that are leaking.. and i think its causing a hesitation from 1500 to 2000rpms where it just bogs down and doesnt sound right.. so theres no other way to get around this guys? i just put out a grand for my ls1 to get the rear done lol.. so im alittle short on money
Old Oct 14, 2009 | 08:08 PM
94Z28LS1toLT1's Avatar
exhaust manifold
i just did a swap and found a couple cracks in the manifold then i took thm to a machine shop costs me like 40 dollars
Old Oct 14, 2009 | 08:14 PM
reamo04's Avatar
i have stock manifolds in my garage. Also have pacesetter mids i'd part with.
linz
3rd Gen / L98 Engine Tech
Oct 22, 2015 07:59 AM
Chris Anderson
Jan 27, 2015 08:30 AM
markaubuchon
Jan 14, 2015 01:48 AM
spearous
Jan 12, 2015 11:03 AM
