exhaust leak from headers
Old Aug 14, 2008 | 11:57 AM
Wld96Z28's Avatar
i have a set of bbk shorty headers w wraps on them. i have just recently changed the gaskets between the haeders and block and didnt have any leaks. the other night i was driving and seem to have burned up or blown the gasket cuz it started leaking while i was driving. any suggestions?
i have been looking at getting pace setter lt headers to free up some more room. could i just modify my y-pipe or do i need to buy the y-pipe they have and would it still be street legal?
Old Aug 14, 2008 | 04:18 PM
If you have header wrap, there's chance you've overheated the metal and possibly cracked a weld. Most header manufacturers void their warranty if you use wrap.
Old Aug 14, 2008 | 05:21 PM
slomarao's Avatar
buy the pacesetter y pipe. Or have one custom made.
Old Aug 14, 2008 | 07:39 PM
Green96Z's Avatar
You may have warped the header flange. Or the bolts could have backed out on you. What bolts are you using?
As for legal, what state are you in? Because running LTs in CARB states is illegal.
Old Aug 14, 2008 | 08:19 PM
ACE1252's Avatar
This is interesting.....
http://www.autoblog.com/2007/12/20/s...own-emissions/
As far as the headers go....just like the others said....check the welds and make sure the flange is true.
It's also possible that a bolt just backed out.....did you re torque them after a heat cycle?
Old Aug 15, 2008 | 10:12 AM
Wld96Z28's Avatar
a couple of the bolts backed out and i blew the gasket. i'll remember this time to re tighten them
i live in culpeper virginia and we dont have any emissons so i dunno if it would be legal or not.
thanks for the help
Old Aug 15, 2008 | 11:55 AM
Green96Z's Avatar
Originally Posted by ACE1252
That deals with the OEM standards of newly manufactured cars. CARB still holds to state emissions laws for aftermarket parts. And it says that you cannot legally move the catalytic converter, which long tubes do. So they are still illegal.
Old Aug 15, 2008 | 12:57 PM
NJ-LE's Avatar
Wld96Z28:
If you're not already using copper exhaust gaskets (the house gaskets from Summit or Jeg's are fine) now's the time to try them! 1" long bolts on the headers are better than the 3/4" kind.
Good Luck
Old Aug 15, 2008 | 04:21 PM
Green96Z's Avatar
Originally Posted by NJ-LE
Wld96Z28:
Good Luck
Not too fond of copper header gaskets. I would go with either the Felpro 1470s or Percy aluminum gaskets.
Old Aug 15, 2008 | 11:05 PM
The law that prohibits moving the cat(s) or changing the number of cats is a Federal law. It applies to all states - some just choose not to enforce it.
My current copper gaskets, along with a set of ARP bolts, have been on the engine for more than 8 years, with no problems.
RUENUF
Mar 13, 2016 03:39 PM
QuickSilver02
Apr 7, 2015 11:12 AM
alex5366
Exhaust System
Feb 24, 2015 09:12 AM
Iamherefornow
Jan 26, 2015 04:57 PM
Brake_L8
Jan 20, 2015 09:44 AM
