Clearance issues for kooks headers?
Old Nov 25, 2006 | 02:52 PM
thegift's Avatar
I have a few questions. First, I will be installing kooks long tubes on a '94 Trans Am GT and I wanted to know if anyone has had clearance problems. Second, what is the difference between long tube and shorty headers?
Old Nov 25, 2006 | 07:55 PM
95z28_m6's Avatar
I dont think that u will have any clearance issues with the kooks headers. They are supposed to be some of the best headers that u can get for the lt1. I have heard alot of people use them without any complaint. Long tube headers are headers that extend past where the stock manifolds stop, usually partially under the car. Short tubes stop just about where your stock manifolds end. You might run into clearance issues with bottoming out a set of longtubes if your car is lowered.
Old Nov 25, 2006 | 10:05 PM
GnarlyZ28's Avatar
kooks
I installed these on my old car (97 Z) and they were a cake walk. There was no clearance problems with any part of the header. I also didn't need to remove the starter, alternator, or jack up the motor.
Old Nov 25, 2006 | 10:44 PM
CamaroSS30thAnn's Avatar
i may have heard some ppl have problems with starter clearance on the kooks stepped headers (1 3/4 - 1 7/8 primarie) but im not sure what was done about that
other than taht i dont think u will have a problem
Old Nov 26, 2006 | 06:57 AM
ABA383's Avatar
Kooks stepped 1 3/4-1 7/8 here...No clearance issues with starter either the stock or LT4 will fit (or any other with similar dimensions...Had to go to an AC PF454 oil filter which I believe is the stock size filter which leaves 1/4-1/2" of clearance and makes it easy to take it off to change the filter...The only clearancing issue was grinding a hair off the steering shaft bolt head where it barely contacted a header tube...May not be an issue for the 1 3/4 non-stepped though...Very nice header with great plug access, fit/finish, ground clearance, etc...highly recommend...
--Alan
Old Jan 1, 2007 | 03:10 PM
SiDeWaYZz28's Avatar
is there an issue with the headers and CANTON oil pans?
Old Jan 2, 2007 | 04:20 PM
2000GTP's Avatar
I have heard good things about Kooks and clearance. Making sure you have motor mounts that are in good shape would also be cheap insurance that you don't run into clearance issues after they are installed.
Old Jan 13, 2007 | 09:34 PM
metallicsniper's Avatar
when did pontiac decide to make a trans am gt?
Old Jan 14, 2007 | 11:23 AM
im like 94 (i think) lol
it ididnt last long , it was just a name
Old Jan 14, 2007 | 11:09 PM
1994, and only in 1994. Might want to read the 4th Gen FAQ:
http://www.f-body.org/faq/4/4_1.htm
[quote]
Queens94z28
Mar 23, 2015 08:06 AM
camaro98_speed
Wheels and Tires
Mar 17, 2015 07:36 AM
akm2131
Parts Wanted
Mar 15, 2015 04:52 PM
birdblack
Dec 30, 2014 06:59 PM
SpeedJunkee
Dec 9, 2014 10:17 PM
