Ceramic Coating a Y-Pipe?
Old Oct 31, 2007 | 04:36 PM
BTC's Avatar
BTC
From: Lansing, MI via Bowling Green, KY: Dalton, GA: Nashville, TN & Atlanta, GA
Is there any benefit, performance or otherwise, in ceramic coating a Y-Pipe, and particularly a stainless steel Y-Pipe?
Old Oct 31, 2007 | 04:54 PM
Probably not much to be gained. Not a lot of heat from the Y-pipe will be getting into the engine compartment. Keeping the heat in the tubes is not an advantage once you get past the primaries, so scavenging is not an issue. Appearance benefits are limited as well, since exposure of the coating to road grime and road salt seems to result in rapid corrosion, even with the cera-metallic coating. Stainless is fine uncoated, although stainless can also be attacked by chlorides where they dose the roads heavilly with salt.
Old Oct 31, 2007 | 05:43 PM
BTC's Avatar
BTC
Thank you. I live in Michigan right now, so there is quite a bit of salt. But I don't really plan to drive the car a lot, especially in the winter, once I get it all back together.
football4life
Oct 4, 2015 07:48 AM
CARiD
Sep 30, 2015 05:44 AM
blaze309
Sep 8, 2015 05:27 PM
Slayer
Aug 17, 2015 03:55 PM
