Can't use fresh ceramic coating during new engine "break in"?
Old Mar 13, 2007 | 09:18 PM
12SCNDZ's Avatar
I wanted to get my headers ceramic coated for the new engine. A local shop that does poder coating also does ceramic coating. They're very specific about not using freshly coated headers on a new motor. Apparently, the coating can't take any more than 700* for the first 30 minutes? They claim header temp will aclipse this during high idle break in periods??? Do all coated headers give this same warning? Any more info on this would be greatly appreciated. Are they just being "overly cautious"?
Frank
CPT
Old Mar 13, 2007 | 09:23 PM
mdacton's Avatar
Thermal tech coatings is local to me....I took mine there and got there new polished/chrome looking coating, I was told to go with it....he said this stuff is good to 1400* I guess it depends on the coating type
The last 2 times I had mine coated by jet hot...the stuff didn't last 2 months
Old Mar 13, 2007 | 09:26 PM
matLT1's Avatar
Frank
CPT
The directions that came with my Coated Hooker Lt's had the same warning.
Old Mar 13, 2007 | 09:27 PM
Flyin_Z28's Avatar
I also have Jet-Hot and they didn't last through one season. They were installed at the on a stock motor with 50K.
Old Mar 13, 2007 | 09:40 PM
myslowcamaro's Avatar
mdacton probably had a better material than the generic ceramics. typical ranges for low end material are 500-700 degrees f. high end commercial run 1000-1500, and industrial (dupont makes some, quite expensive tho) for nasa, steel mill blast furnaces, etc can handle 2500-3000 degrees.
the biggest problem is you cant have all the necessary properties to hold up for very long if you're greedy, meaning they can do 1000 degree coatings and it might be metallic to hold color and heat resistance, but it will corrode. so you go to a epoxy-organic nitrate mix to deter corrosion, but now they look like hell from the heat.
a company like jet hot isnt going to spend $900 for premium coating when im sure their dipping vats need at least a 100 gallons and lose material to dripping and splashing. cant justify or stay in business for a set of $1000 headers when its all said and done. cheaper to replace your rusted ones down the road
Old Mar 14, 2007 | 02:56 PM
sseeya's Avatar
Here's what a paper that came with my Jet Hot coated Pacesetters said:
Caution
Protect your engine
During tuning of certain engines, especially new ones, lean or rich/fuel air mixtures can cause hot spots well in excess of 1300 degrees, with potentially adverse effects to the header and possibly the engine. We STRONGLY recommend the use of a large floor fan to cool the engine and headers during this period. Or, if avaliable, use an old set first for tuning. FAILURE TO TAKE THESE PRECAUTIONS COULD RESULT IN PERMANANT DAMAGE TO THE COATING.
Ignition timing is CRITICAL to exhaust temperatures, which are not reflected by the water temperature guage.
Old Mar 14, 2007 | 07:25 PM
FASTFATBOY's Avatar
What coating did you use? Jet Hot has many, I popped for the Jet Hot 2000, good to 2400 degrees, hope it lives.
David
Old Mar 14, 2007 | 07:33 PM
mdacton's Avatar
David
the 2000....I was told by thermal tech that they use a water based ceramic coating and he gets them in everyday
What gets me is there lifetime warrenty....its a load of crap, they won't stand behind it, they did them the first time after I complained for 2 months...then I paid shipping down there...they would not ship em back unless I paid shipping. I will never deal with them again and I will tell my story to everyone I meet
I went with these guys....they really know what they are talking about and are local to me http://thermaltechcoatings.com/
Old Mar 14, 2007 | 08:01 PM
2000GTP's Avatar
The Pacesetter coatings aren't much better as mine lasted less then a years time on a car that is rarely driven and sees no rain or road salt. Maybe I'll have to check out these guys as I was hoping to get my headers recoated.
Old Mar 14, 2007 | 08:04 PM
mdacton's Avatar
they have this stuff that looks like chrome....thats what I got this time, its pretty expensive but he garentees them, I like the fact that I can just go down there and take care of a problem if one pops up
Old Mar 14, 2007 | 08:07 PM
2000GTP's Avatar
How much did that service run if you don't mind me asking? It looks like they would roughly charge around 250.00 to coat a set of long tubes? Also noticed they do powercoating services.
Old Mar 14, 2007 | 08:11 PM
mdacton's Avatar
I will let you know friday....I just told him to do it, he told me it cost more I said I dont care as long as you stand behind it.
They have some pretty cool stuff there, all types of coatings for alot of stuff.
thing that sucks is we don't have any real chrome shops here anymore
Old Mar 14, 2007 | 09:31 PM
FASTFATBOY's Avatar
Boy I am gonna be SEVERLY pissed if mine comes off, good thing about me, I am 40 miles from Jet Hot. I will be in someones office. That **** was $450
David
Old Mar 22, 2007 | 08:55 PM
Loadre's Avatar
Do they not think EGTs get above 700* any other time? That reasoning is ****ing retarded IMO.
Old Mar 22, 2007 | 09:31 PM
ws6transam's Avatar
I've created an eight channel EGT module and monitored exhaust gases for most of the summer of 2005. At idle, temps hovered in the low 700's. Under cruise conditions, it was in the 1100's, and under hard acceleration it would peak at 1300 (+-50 degrees) on average, across the eight cylinders. Turbo apps can sometimes spike at 1700, but usually are in the 1300 range.
armedtrigger
Feb 24, 2015 08:30 PM
99TransAmWS6
Feb 12, 2015 07:23 PM
ModdedNerd
Jan 29, 2015 07:23 PM
Jcb890
Sep 9, 2002 11:30 AM
kandied91z
Jul 20, 2002 03:56 AM
