4th Gen Exhaust on 3rd Gen
Old Jan 13, 2008 | 09:24 AM
Steven LS1 Z28's Avatar
Has anyone put a 4th gen exhaust system on a 3rd gen car. My '91 Z28 needs a new exhaust, and I have the stock system from my '98 Z28 that I coud use if it will work. I'm sure that I will have to do some modification from the manifolds to the y-pipe. Will this swap work?
Old Jan 13, 2008 | 10:27 AM
Green96Z's Avatar
No. Your 98 Z28 has the LS1 engine, which has a different exhaust port setup on the heads than a traditional SBC. So the primaries would not align correctly. Plus the header bolt design is different.
Old Jan 13, 2008 | 11:24 AM
I will not be using the LS1 manifold, only the Y-pipe back.
Old Jan 13, 2008 | 01:02 PM
reamo04's Avatar
go try it?
If you use the 3rd gen y-pipe, then all you will need to do is get it to connect to the 4th gen intermediate pipe assuming everything else will work (hangers, etc)
Old Jan 26, 2008 | 10:31 PM
sn8ke eatr's Avatar
no it wont directly bolt on but if you got a little skill you can make it work, the pipe routing and muffler location are basically the same, youd need to figure out how to mate the I pipe with the Y pipe of the 3rd gen
Chris 96 WS6
33
Sep 3, 2002 09:48 PM
stars1010
Jul 15, 2002 03:51 AM
Doug Harden
11
Jul 14, 2002 04:31 PM
formula79
23
Jun 20, 2002 01:42 PM
