long tube exhaust sound..
Old Jan 7, 2008 | 07:49 PM
BlkZ28Kreepn's Avatar
i'd like to go with long tubes, but the cars i've heard sound loud and hollow, im guessing cause the straight pipe,since no room for a resanator,cats..i'll be going with pacesetter long tubes,pace setter offroad y-pipe,to a cutout,magnaflow muffler...i want to get a nice deep rumble out of it, will the pacesetters provide that? or is there a different y-pipe setup i could do to get that deepness i want? thanks for any help..
Old Jan 7, 2008 | 08:16 PM
white97T/A's Avatar
What kind of car/motor etc.? Those variables have a lot to do with how "it" sounds.
Old Jan 7, 2008 | 08:23 PM
they will be going on a 94 z28 lt1 bolt-ons,cam,stock heads..not sure as far as the specs on the cam are..do you know of any website?links or sound clips?
Old Jan 7, 2008 | 10:10 PM
96z28t56's Avatar
You can try http://ls1sounds.com/ , Theres a couple LT1's on there
Old Jan 20, 2008 | 11:33 AM
ROL WTME's Avatar
the pacesetter setup will be fine, it's what I have. If I were you I would go with true duals.
Old Jan 20, 2008 | 12:09 PM
rickjames343's Avatar
See if you like this, its my 97z28 with a hotcam idling thru pacesetter LTs, pacesetter ORY, closed 3" cutout, and magnaflow catback.
http://videos.streetfire.net/video/1...e2012adcac.htm
Old Jan 25, 2008 | 10:01 PM
RS96Silver's Avatar
that thing sounds BA...makes me what my LTs to go on now! to bad i dont have time to do it right now
Old Jan 27, 2008 | 06:27 PM
sounds good, by any chance do you have a video with the cut out open?
Old Jan 27, 2008 | 08:40 PM
Nope, sorry....that right there was the last time it cranked. Always make sure you clean out blasting sand from your intake, otherwise it'll get into your piston rings and destroy the whole inside of your motor.
Old Jan 28, 2008 | 07:36 AM
2000GTP's Avatar
I would search around a bit, there are alot of setups out there. Alot of how it sounds will have to do with the catback you choose as well. Also, if you find a small enough sized cat, you can pull off having a catted off-road y-pipe.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
Jan 5, 2015 07:14 PM
SpeedJunkee
Dec 9, 2014 10:17 PM
Queens94z28
Nov 20, 2014 06:03 PM
