Worn out C-Clips?
Old Sep 22, 2008 | 10:10 PM
eagleknight97's Avatar
Worn out C-Clips?
My rear brakes both make noises like they are constantly dragging on the caliper bracket or something and this has been going on for a while. I remember hearing somewhere that c-clips can wear out and cause problems similar to this. So could that be causing the problem I am having? Also, how hard/how much would it cost to get them replaced?
On a possibly unrelated/related note, both my ASR off and ABS lights are on in my dash and im not quite sure why. Any ideas?
Old Sep 23, 2008 | 07:30 AM
1SlowFormula's Avatar
well I know my C-clips wore out in the stock rear many years ago with only about 60-70 K miles on the clock. When going around a corner you could hear the axle shift out and start dragging caliper on the rotor... I will do a quick search because I think I have pics of it somewhere...
As for the ASR and ABS lights since you have a 4 sensor setup there are sensors at each wheel, and if there is contact from the axle shifting due to the C-clip the sensor is more then likely screwed. They are pretty much magnets that are close but not touching that read a spinning ring, and if things shift it could cause issues...
Old Sep 23, 2008 | 07:36 AM
well here are some of my old posts about this similar issue, but couldn't find the pics...
http://web.camaross.com/forums/showthread.php?t=392118
http://web.camaross.com/forums/showthread.php?t=450702
http://web.camaross.com/forums/showthread.php?t=351187
Old Sep 23, 2008 | 09:50 PM
Originally Posted by 1SlowFormula
Thanks for the help. My car used to grind when I would turn, but it stopped doing that out of nowhere and was fine for a few months. Then, once I stopped driving it alot because I got my truck, the rear end started making this noise. It sounds like a constant rubbing/scrubbing noise from both sides.
Old Sep 24, 2008 | 04:45 PM
slomarao's Avatar
THe diff is probably gone. My car did the same thing. how many miles on it?
Just a fyi, when i replaced the c clips the noise went away for a while. But it slowly but surely came back, so it may work as a temp. fix but i wouldnt trust it for the long haul.
Is the noise you get a metal on metal screech?
Old Sep 24, 2008 | 05:00 PM
It not a screech, it sounds more like a scrubbing, almost like sandpaper on wood, but a little different.
IndyZman
Oct 22, 2015 02:17 PM
football4life
Oct 4, 2015 07:48 AM
Z28-50
Aug 7, 2015 01:22 AM
realistyc
Jul 28, 2015 07:32 PM
mattszm6
Dec 14, 2014 07:09 AM
