Will 95 4L60E fit my 94
Old Jan 17, 2006 | 03:54 AM
datkwikracer's Avatar
Ok i did do a search and i did find some info but here's my problem. my tranny went out in my 94 Formula so I got one from a 95 form a guy who swapped for a 6-speed. I removed the old tranny and was about to put on the 95 when i noticed that the harness connection had an extra pin 13 compared to 12 in my 94 tranny.
Is there any way i can make this work on my 94 do i have any options? should i just sell the 95 and look for a 94? Do only 4L60E's from f bodies fit or can i use a caprice/truck 4L60E?
I would prefer to use the 95 tranny if there is a way i can use it.
If not does anyone know of a good rebuild shop in so cal? I just want a stock to slightly better than stock rebuild for daily driving mostly.
Old Jan 17, 2006 | 07:49 AM
Re: Will 95 4L60E fit my 94
The 1995 uses a pulse width modulated TCC solenoid. That's the extra wire. I think you can use the 95 transmission, but need to do some slight conversion in this area. You might only need to swap out the TCC solenoid, but I am not sure of the specifics. Hopefully someone that knows will chime in.
Old Jan 18, 2006 | 05:02 PM
thanks anyone else?
Old Jan 18, 2006 | 05:28 PM
12SCNDZ's Avatar
Sorry...I've shyed away from this post, simply because I don't like to swap transmissions into the wrong year vehicle.
You might be able to block the TCC regulator valve in the '95 valve body, essentially turning it into an on/off lock-up, instead of PWM. This will require removal of the valve body, and a new spring to istall in the valve. I believe enerything else will be OK, because your computer won't see the PWM solenoid.
Frank
Old Jan 19, 2006 | 05:15 AM
wow, reads pretty complicated i think i would i be better off looking for a 94 tranny
my next question would be could i use a tranny from a 94 caprice? or a 94 v6 camaro/firebird?
Old Jan 19, 2006 | 07:15 AM
Javier97Z28's Avatar
Moderator
I can't vouch for the Caprice, but the V6 models have different bellhousings and are not compatible.
thenewkid
Apr 12, 2015 07:42 PM
Apr 3, 2015 10:54 AM
mschmidt33
Mar 15, 2015 07:20 PM
Noer
Feb 28, 2015 11:29 AM
Camaro_Eric
Aug 8, 2002 12:21 PM
