Where does the speedo gears go?
Old Mar 31, 2004 | 08:47 PM
mickeyiz28's Avatar
Im about ready to change my gears so i bought some speedo recalibration gears for my 93z, does anyone know where i need to replace my new speedo gears, is it in or out of the transmission?
Old Mar 31, 2004 | 08:56 PM
Capn Pete's Avatar
I thought that all 4L60E's had electronic speed sensors, and no longer used mechanical gear-drive speedo gears? However, I know there were a few things different in '93, so IF you've got the little gears inside the tranny for the speedo, they would be on the passenger's side just ahead of the tailstock (I think? ) with the speedo cable running to it. If you've got the speedo cable running to the tranny, you can't miss it. I'd double check first though, 'cause you may need to have the computer re-calibrated for the gear change instead.
Old Apr 1, 2004 | 08:38 AM
mongse_1's Avatar
'93s used a 4L60 (basically a 700R4), so they would still use the recal gears. Your description of their location is right though. Both my old 4L60E and my current TH400 have the speedo gears on driver's side of the tailshaft. There's a small bolt (10mm??) that you have to take out to remove the sensor. You may have to take the tailshaft off though...I had to on my 400 to put the electronic sensor & correct gears in.
Old Apr 1, 2004 | 04:28 PM
mickeyiz28's Avatar
so i do have to pull the tranny to change those gears??
Old Apr 2, 2004 | 10:03 AM
mongse_1's Avatar
Not sure, I did my 400 on a workstand. I think there's enuff room to get in there and swap them out under the car though.
blac94Z
Feb 10, 2015 11:02 AM
Jul 4, 2005 05:00 PM
Nostang 96z
Sep 10, 2002 08:54 PM
Dr. Weir
Aug 2, 2002 02:36 AM
