What Trans would be best
Old May 14, 2008 | 08:00 PM
83trnsamlt1's Avatar
I'm Putting an LT1 into an 83 trans am. What would you think would be the best trans for the motor and car?
Old May 14, 2008 | 08:27 PM
Performabuilt's Avatar
Supporting Vendor
I would go with the 700R4
Old May 14, 2008 | 08:46 PM
1987IROC350's Avatar
I, being a non-gearhead, went with a 700R in my crate install. I'm glad I did. It's very streetable compared to a 3 speed auto. And no mods were necessary. Although I have found less shifters and torque conv. choices are available for the 700R compared to a 350 or 400.
Is the 1993 Z28 auto trans non computer controlled like the 700R? If it's not computer controlled maybe it would hold together better considering it was made to go with the LT1.
Old May 14, 2008 | 09:55 PM
Is the 1993 Z28 auto trans non computer controlled like the 700R? If it's not computer controlled maybe it would hold together better considering it was made to go with the LT1.[/QUOTE]
This is something that i would have to lok into. never thought of that before
Old May 15, 2008 | 12:46 AM
Ok I can't sleep. The early 1993 Z28 came with the 4L60. Its Later years were the 4L60E and 4L65E. Anyway the 4L60 uses a tv cable like the 700R. So you can use it easily.
Old May 15, 2008 | 06:03 AM
12SCNDZ's Avatar
You'd need a 1993 TV cable, bracket, and throttle body. We could supply the correct cable, and bracket with a rebuild. Your '83 also came with a 700R4, so mounting it would be easy, as would just using a 1983 dipstick and tube.
We have 700 cores available. A "Pro Race" 700 that's 9 second capable will run you $1600 + shipping, or a "Race" unit would run $1300. The cable and bracket are right around $40 for original GM parts.
If you're goping to do alot of street driving, you can't beat a PROPERLY BUILT O/D with lock-up. A 700 R4 is the obvious choice.
Give me a call, if I can be of any assistance.
Thanks,
Frank
CPT
302-250-1202
force10
Aug 10, 2015 08:30 AM
ricks95TA
Jul 23, 2015 12:59 AM
jackpawt883
Jul 20, 2015 06:32 PM
dolfan324
Jul 17, 2015 10:34 PM
Fastbird93
Jul 11, 2015 04:37 PM
