What gear to use
Old Nov 30, 2004 | 07:05 PM
papatate's Avatar
Question What gear to use
I have a 350 in a 84 Z28 with a TH-350. need to know what gear to use. Right now it has 4.10 but around 55 mph I'm turning about 3000 rpm. And I think that is way to much. So would 3.42 be better? Are should I go with a P275/60R15 over the P235/60R15 that is on the car now?
Old Nov 30, 2004 | 07:09 PM
dmoor88's Avatar
Re: What gear to use
Are you using a 10-bolt? I'm personally very happy with my 3.73's. I'm turning 2000 RPM's at 75 mph and 2500 RPM's at 90 mph, with a M6 of course. With your TH350 I wouldn't go with anything over a 3.73 gear.
Old Nov 30, 2004 | 07:18 PM
papatate's Avatar
Yes I,m useing a 10 bolt. Because I ,got to buy the gears so I don"t want to get the wrong gears this time. So 3.73 should put me around what rpm with a TH-350?
Old Nov 30, 2004 | 07:22 PM
dmoor88's Avatar
The reason I got my 3.73's was becaue my car was an auto to begin with. For the life of me I can't remember what RPM's I was turning at what speeds. I know there's a formula but it escapes me. I'm sure someone else would be able to help ya!
Old Nov 30, 2004 | 07:45 PM
papatate's Avatar
Thanks. Hope to get more information.
Old Nov 30, 2004 | 08:56 PM
rskrause's Avatar
Moderator
26" tire/3.73's
60mph = 2,900rpm if there is no conveter slip. If it's a loose converter, it will be a few hundred rpm higher.
Rich
Old Nov 30, 2004 | 09:38 PM
papatate's Avatar
I'm going to be running a P275/60R15 so to run 60 at about 2400 I would need to be around 3.23 right?
Old Nov 30, 2004 | 09:49 PM
Capn Pete's Avatar
This should help a little .
blkWidow
Apr 21, 2015 01:56 PM
CARiD
Apr 8, 2015 08:08 AM
alex5366
Apr 1, 2015 09:27 AM
ChrisFrez
Mar 22, 2015 09:12 AM
