twin clutch toast!
twin clutch toast!
hey guys, ive been putting my car together for 2 years now and its finally done.
so, today was the big day,i trailored it to the dyno to put down some #s and tune what needed to be. i could feel the clutch wasnt fully engauging, so we got it up on the lift and tried to fix it.
originally when i installed the clutch i read on the message board here, that i needed to grind down the point where the pivot bolt bolts the fork to the tranny. did that. once clutch was installed, i noticed it wasnt engaging fully so i was told to remove the rod from the slave that moves the fork in and out,and cut it 1/8", re-install it and continue this procedure untill it engaged fully. so after cutting off about 1/2" it seemed to be better so i made a few test runs on the road and it went from good to bad real fast. so i left it alone and figured that when i brought it to the dyno, i would just remove the rod again and cut it another 1/4" and it would be all good.
well thats what we did......and i was wrong. it wouldnt even grab enough to roll onto the dyno wheel, we had to push it on. so at this point i knew it the clutch was toast so we tried one pull just for fun and at 3000rpm it wouldnt spin the wheels any faster.....
so i need a new clutch. its a mcloed streettwin with steel flywheel that i bought here on the message board. it was used but for only about 1000 miles. seemed fine when i got it so i installed it.
so what i need to know is, can i just buy two new clutch discs and keep the flywheel,pressure plate and throwout bearing, or do i need a whole new clutch kit? any thoughts would be appreciated as i want to get this car on the road finally and on the dyno as well. thanks
My car just got running yesterday after the install, and I used the adjustable master from them too.
The clutch releases great and has a great feel to it. It is a grabby little bitch though. Me likey!
when i bought my clutch i did a search on here before installing it and everyone was saying they had problems and the fix was to grind down the T-bolt that bolts the fork to the tranny.
then once we fired it up and i tried it it wasnt engaging very much, just at the very top so i called a local shop and he told me to remove the rod on the slave and cut it 1/8" at time trying after each cut and it never really helped. i think i may have ground to much off the T-bolt. im bringing it in to a shop wednesday morning and theyre gonna look at it.
maybe the clutch is still fine as it never really got to engage and the can just put a stock T-bolt back in. hopefully thats the case.
from what i read if you didnt grind down the T-bolt the fork would come in contact with the bellhousing. thats just what i read though. you would have noticed right away if there was a problem as the clutch would be hard to push in as the fork we jam on the bellhousing. maybe the newer ones dont have this clearnce issue. i even got suckered in on buying the billet adjustable master($320) and apparently you can use the stock one with no problems. any how, the car is at very well known tranny/diff shop getting fixed so i should know tomorrow what the problem was.
The ORIGINAL (late '90s) Street Twin required about 1/10" to be shaved off the pivot, and included a "sleeve" that had to be inserted in the slave cylinder. I believe they did away with both those when they added the adjustable master cylinder.
Ok, so this was waaay before the clutch design I have now. Thanks for chiming in Injuneer!
