Turbo350 trans?
Old Jul 14, 2007 | 08:44 AM
hairbear's Avatar
Turbo350 trans?
I have a older 3-speed automatic trans in a 95 camaro and was wondering if there is way to make the speedometer work with it
Old Jul 15, 2007 | 10:37 AM
12SCNDZ's Avatar
Yes...Take it back out and put the right transmission back in it
Seriously, though. Yes, you have to take the 350 back out and have a conversion installed that replaces the output shaft. The kit is made by Fitz-All, and will run you right around $200. The transmission needs to be completely disassembled to change the shaft.
What are you mounting your torque arm to? How is your mount/crossmember set up? What driveshaft? What length TH350 are you using?
There are numerous threads from others who've done this uneccessary conversion from an A4 to the 350, although we still can't figure out why. You lose O/D, the car will 60 ft. worse, and it's not any stronger. The ONLY time a 350 makes any sense in a 3rd or 4th gen is if you want a transbrake.
Frank
CPT
Old Jul 15, 2007 | 11:17 AM
hairbear's Avatar
I agree with 1st statement.lol I took this car in a trade on my 91 I had and for the life of me couldn't figure out why it was done either. Figure he spent cpl hundred on the converter it has,cpl more on the pistol grip shifter(I do kinda like that) the trans itself and a rear gear to help the trans out. More than enought to have hade the 4l60e rebuilt.
Was hoping it was an easier fix than that.lol
Old Jul 15, 2007 | 11:57 AM
12SCNDZ's Avatar
Give me a call, and I'll try to help you out. 302-250-1202
Frank
CPT
Old Jul 15, 2007 | 05:34 PM
lethal93ta's Avatar
I wonder if you couldnt use a sensor off a 93 TA it uses the the gear type sensor but is electrical. did anyone over try that? it should fit in the TH350 hole for the speedo, I know its the same size as my TH400 hole for the sensor to fit into. when i was thinking about doing a TH350 that what I was going to try to do but I decided to go with the real deal 400.
Old Jul 15, 2007 | 11:51 PM
n20ta2's Avatar
I bought a vss translator from dakota digital for 50.00 that screws into the th-350 speedo on the output and replaces the mechanical signal for a signal the computer understands. much cheaper then your other options.
force10
Aug 10, 2015 08:30 AM
ricks95TA
Jul 22, 2015 10:15 PM
jackpawt883
Jul 20, 2015 06:32 PM
dolfan324
Jul 17, 2015 10:34 PM
Fastbird93
Jul 11, 2015 04:37 PM
