Transmission temps
Old Apr 20, 2006 | 05:26 AM
Honda Hunter's Avatar
Transmission temps
How cool is to cool and what is optimal? I see plenty of talk about getting more than one tranny cooler and I cant see the point as long as you have one that's efficiant.
Old Apr 20, 2006 | 08:31 AM
rskrause's Avatar
Moderator
Re: Transmission temps
180-200 is a good operating range.
Rich
Old Apr 20, 2006 | 09:45 AM
EVERESTZ28's Avatar
rich...
i would like to make a 5 hrs trip, but i think i will need to be 3000-3500 rpms in OD to achieve 100-110 mph, do you think i can overheat the transmission???
I don't have a temp gauge for transmission oil, i have a radiator for oil transmission.
thanks
Old Apr 20, 2006 | 01:57 PM
rskrause's Avatar
Moderator
Originally Posted by EVERESTZ28
rich...
thanks
I was glad to see the aftermarket pan in your sig to go with the HV pump, as this is one of my pet peeves. Anyway, if you have a lockup converter, no problem at all. If it's a non-lock up you really need a tranny cooler.
Rich
Old Apr 20, 2006 | 02:33 PM
Rich
That's what I wanted to here. I have the same tranny cooler as you and mine stayed at 180 +or-3.
Old Apr 20, 2006 | 02:48 PM
rskrause's Avatar
Moderator
That B&M "Hi_Tek" cooler is the shizzle. Mine stayed 180 with near 1K hp going through a non-lock up 4,200 stall converter in a ~4,000lb car!
Rich
Old Apr 20, 2006 | 03:05 PM
Rich
Awesome. I still have never seen my fan work though.
Old Apr 20, 2006 | 03:53 PM
rskrause's Avatar
Moderator
Mine was on a lot. You proabably aren't generating as much heat.
Rich
Old Apr 20, 2006 | 03:56 PM
Where can I buy a different sensor to allow my tranny fan to run at a lesser temp?
Old Apr 21, 2006 | 12:47 AM
revtime's Avatar
Rich
I second that. Mine has not gotten over 150 yet. My sensor is in the pan though, and I have yet to go more than about 5 miles up the hiway to the next exit and turn around and come back.
Hopefully I fixed the oil leak I had and can start to venture farther from home.
Magenta_Hearts
Mar 29, 2017 08:54 PM
sherwinZ28
Jun 6, 2015 08:48 PM
Jul 4, 2005 05:00 PM
Rich_z28
May 6, 2003 08:38 PM
