transmission problem maybe??
Old Jan 3, 2007 | 08:12 AM
Terran2k's Avatar
when Im driving on the highway around 55-70 and I take my foot off the gas, It feels like its engine braking, i guess that would be the term? I used to be able to coast for a long time, but now I lose mph alot faster than I used too. It used to do this once here and there as of late last year, now it seems to do it always. Rebuild in my future? well most like an M6 swap if it doesnt give up too soon on me.
Old Jan 3, 2007 | 09:51 AM
OBE1 95Z28's Avatar
Does the car shift into overdrive (4th gear)? Sounds like you're in 3rd, not overdrive.
Old Jan 3, 2007 | 10:33 AM
camaro322hp's Avatar
when you take your foot off the gas on the highway, you could try manually shifting into 3rd. if you feel no change, then you were already in 3rd.
(of course, i don't own an auto tranny, and i'm assuming that on these cars, you can manually shift down into 3rd)
EDIT: OBE1, you've been on this board a LONG time!!
Old Jan 3, 2007 | 10:41 AM
Performabuilt's Avatar
Supporting Vendor
The lockup clutch may not be disengaging which will cause more of a braking effect when you let of the throttle , This is likley since it was intermittant ,
I would have it scanned and see if the clutch is unlocking it should unlock at 0 throttle coasting ,Possible causes would be a bad TPS not letting the ecm know that that it was coasting
Old Jan 3, 2007 | 11:58 AM
12SCNDZ's Avatar
Does the transmission upshift through all 4 gears normally?
Frank
CPT
Old Jan 3, 2007 | 12:09 PM
Terran2k's Avatar
just so I do not give you all mis-information, when would my car shift into 4th gear?
Old Jan 3, 2007 | 01:51 PM
henryz28's Avatar
My car shifts into overdrive (4th) at around 45mph.
Old Jan 3, 2007 | 02:00 PM
Terran2k's Avatar
Okay, I am at work right now, but when I leave I'll count the shifts.
Old Jan 5, 2007 | 02:44 PM
Terran2k's Avatar
It shifts thru all the gears, counted them, 1 to 4, normal throttle up to 65. It didnt act up the last couple days, but I know the problem will return as it always does. What do you all think?
warmeck
Mar 16, 2015 07:02 AM
jmadoll
Mar 3, 2015 10:16 AM
jackpawt883
Feb 26, 2015 09:04 PM
edxiel
Jan 24, 2015 07:40 PM
Cam's maro
Dec 28, 2014 09:30 AM
