Pro 5.0
Old Jan 5, 2007 | 01:34 PM
SC/TA's Avatar
Pro 5.0
For those of you who shortened your shifter, How much did you cut off? Do you have to rethread the shifter when useing the factory ****? I have one on order and I am trying to get some info before it gets here. Thanks
Old Jan 5, 2007 | 01:39 PM
Zepher's Avatar
I went with the Lou's short stick with the bend in it.
I need to find my stock Pro 5.0 shaft as I am going use that one instead now because my Corbeau seats sit a bit higher now and the shortened bent shaft hits the seat in second gear.
from what I remember, the stock Pro 5.0 shaft had about 2 inches of thread, so there is plenty to use after cutting it.
Old Jan 5, 2007 | 01:40 PM
Klypto's Avatar
i just got the lous stick. ppl say its the same thing. i heard you put a bolt on it, cut it, then just unscrew the bolt and it re threads it for you. not sure if true, never done it.
cory
Old Jan 5, 2007 | 01:54 PM
SC/TA's Avatar
Thanks guys, where did you get the Lou's short stick?
Old Jan 6, 2007 | 12:21 AM
PWR-TRIP's Avatar
http://www.afterthoughtsauto.com/lousshortstick.html
Don't forget to loc tight your nuts
Old Jan 6, 2007 | 01:14 AM
Klypto's Avatar
what he said... thought they were tight anough few yrs back and kept coming loose...
all good when do it right
Old Jan 6, 2007 | 01:49 AM
SC/TA's Avatar
Thanks for the info guys.
Quickss96
Jan 29, 2016 05:56 PM
9t4lt4z28
Oct 2, 2015 10:28 AM
Z Power
Sep 19, 2015 11:19 PM
Daluchman1974
Sep 11, 2015 06:12 AM
95z_28_camaro_4_Ivan
Aug 25, 2015 03:59 PM
