Transmission HELP!!!!!
Old Jun 18, 2004 | 08:50 PM
LT1CST's Avatar
Hey Tranny GURUS. Just wondering. I have a 4L60E tranny in my LT1. I finally figured out why it was not shifting after the new motor. (low ATF) Now for some reason the clutches 1-2 are really bad. IN fact the gear races the engine up on the transition from 1st to 2nd, I wanted to know I plan on going with a Manual Valve Body. With shift Kit. IF I Get those parts installed will that eliminate my Transmissions slips. And how fast will the shifts be with a FULL MANUal Valve body?? Thanks
LT1CST@aol.com
CHris
Old Jun 19, 2004 | 12:03 AM
Capn Pete's Avatar
I'm not a tranny "guru", but I think you may have hurt your 1st + 2nd gear? Running with low/no ATF is not good. If you pull it apart to install a shift kit and/or manual valve body, be prepared to replace 1st & 2nd clutch packs, or whatever the parts are?
Old Jun 19, 2004 | 02:15 PM
LT1CST's Avatar
I gotta bad leak coming from some were ITs leaking all over my Jet hots/ Prolly why its not shifting to its full potential cuase its loosing ATF. I gotta get that fixed. Will LOSS of ATF make the gears shift slow and even slip??
Chris
ttt
Old Jun 20, 2004 | 12:25 AM
Pro Built Automatics's Avatar
Loss of fluid will destroy the transmission, which in your case sounds like it did.
football4life
Oct 4, 2015 07:48 AM
4586
Sep 27, 2015 01:55 PM
cristian1311
Sep 12, 2015 08:16 PM
Daluchman1974
Sep 11, 2015 06:12 AM
92_RS_305
Sep 8, 2015 07:47 PM
